Spooky Electronics
Old Jan 5, 2012 | 12:25 AM
rocklin-ron's Avatar
rocklin-ron
Default Spooky Electronics
I am the second owner of a 2005 C6 coupe A4 that is totally unmodified. It is my daily driver and I have put about 20K on it in the past 3 years, for a total of 32K. Over the past half year I have had some spooky electronic events, all of which go away soon or at least at the next startup. None has been a show stopper, so I have not been very concerned. Events include:
1. A DIC warning that the right front tire was flat (not so)
2. A DIC warning to service the active handling system (gone at the next startup)
3. A disappearance of the passenger side temp setting plus the sudden turning on of the radio with a loss of all station presets (all was back to normal at the next startup)
4. Many times when I stop the engine on the lower left of the switch, the accessory setting flashes and I have to press stop again.
I really enjoy the car but the above nonsense puzzles me.
rocklin-ron
Old Jan 5, 2012 | 07:15 AM
C7Joy's Avatar
C7Joy
Maybe the battery is going south? That has been know to cause some crazy effects from many posts I have read here.
Old Jan 5, 2012 | 07:19 AM
R&L's C6's Avatar
R&L's C6
Throw a new battery in it. It's the cheapest and easiest place to start.
Old Jan 5, 2012 | 07:49 AM
Vette_DD's Avatar
Vette_DD
I had 36K miles on my DD 06 when it was 4 years old and had to replace the battery.
Old Jan 5, 2012 | 09:16 AM
drclaw's Avatar
drclaw
I got the "RIGHT REAR TIRE FLAT" message on the DIC many times (it would clear after a minute or so) several times, so I had that sensor replaced. It has only happened once since...so still weird.
I put a new battery in, and all seemed well for a while...but last Sunday, the power/volume **** on the NAV wouldn't power the system off...but it would adjust the volume. Worked fine after turning the car off and back on again.
Sorry I'm not actually providing any advice beyond "Now that you mention it, my car has weird electrical gremlins sometimes too."
Old Jan 5, 2012 | 12:43 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
rocklin-ron
#1- sensor battery is probably dieing, replace sensor if problem continues. Replace all four sensors at next tire change.
#2- Service Active Handling is usually caused by a loose connection in the steering column wiring. There is a bulletin for this, and it may have become an actual recall. Check with your dealer, the fix might be free. If it contines, turn off AH and get it fixed promptly.
#3- Loose connection somewhere? Even removing the car battery did not cause us to lose the radio presets.
#4- If you look carefully in good lighting, you'll see the engine start/stop switch does not have a right or left side, it's all one piece. Just those little lights foolin' with you.
If you press the bottom of the switch just a little too long while shutting down, you go from Run to Off to Accessory. Then, you need to press the bottom of the switch again to get out of Accessory.
And as others mentioned, a weak main battery can cause a whole slew of oddball electrical issues.
Glad to see you're enjoying your car!
Old Jan 8, 2012 | 02:00 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
rocklin-ron,
Has your concerns been resolved? Please feel free to keep me updated and contact me if you need any further assistance. Thank you.
Tricia, Chevrolet Customer Service.
Old Jan 9, 2012 | 01:13 AM
rocklin-ron
Thanks to Gearhead Jim for the starter switch response. For 3 years I had thought it mattered which side of the bottom portion of the switch that I pushed, even though I realized it was a one piece switch (duh!).
Regarding the other comments, I have an Optima Red Top battery that is 2 1/2 years old. I checked a start yesterday with a "Battery Bug" and it rated at 83%, which is quite good.
I have not had any further strangeness in the past 2 weeks.
rocklin-ron
Old Jan 9, 2012 | 07:08 PM
rocklin-ron
Relative to Item 2, I forgot to say that the car has completed recall campaign 10118 for installation of a clip into the steering postiion sensor.
rocklin-ron
To Spooky Electronics
