Brake noise
Old Jan 5, 2012 | 05:52 PM
CPTAHAB's Avatar
CPTAHAB
Default Brake noise
2011 C6 6k on odo-noticed some brake squeal when braking over 40mph. Just noticed. Any issue? In FL cold snap possible cause?
Old Jan 5, 2012 | 06:57 PM
BC427's Avatar
BC427
No issues. Welcome to the wonderful world of semi metallics.
Weather will influence brake noise.
Let the opinions begin.
Old Jan 5, 2012 | 07:08 PM
CPTAHAB's Avatar
CPTAHAB
Thanks!
Old Jan 5, 2012 | 08:03 PM
indyjack18's Avatar
indyjack18
Be thankful you got to enjoy 6,000 miles of silence
I've found if I run'er to 60-70mph and brake HARD a couple times in a row the squeal shuts up for awhile. You could do a search on bedding the brakes.
Old Jan 5, 2012 | 08:15 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
I had that. I put on Hawk ceramic pads and it went away!
Old Jan 5, 2012 | 08:21 PM
hig4s's Avatar
hig4s
My old Acrua TL did it occasional also, I used the same method to quiet them..
So far my Vette has not started squealing.
Old Jan 5, 2012 | 10:10 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
Originally Posted by brettbolt
When I first bought mine I tried everything to get rid of the squeal.
The only thing that worked was bedding the brakes as previously suggested. But it lasted only about 2 weeks, then the squeal came back.
You'll get used to it. I finally did.
No way!! I did the exact same thing with the same result. Trust me. All I did was change the front pads to Hawk ceramics and the squeal is gone. I was tired of sounding like a 72 pinto when I was coming to a light!!
Old Jan 5, 2012 | 10:20 PM
Cherokee Nation's Avatar
Cherokee Nation
I had NO squealing with the pads that came with the car,i changed over to the GM ceramics pads for the brake dust problem,and i did bed them in,and they squeal all the time,,.SUCKS,.,
Old Jan 6, 2012 | 01:21 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
No need to act like a know it all and call BS. I know what I hear. The squeal is clearly audible with my GM Ceramics. Would you like to hear it in person?
That's my point. Not trying to be an AHOLE!! Sorry if it looked like that. I had the excact same thing you are having!! The GM ceramics are freaking noisy!!! No matter how many times you bed your brakes it keeps coming back (at least with me it did). I was more worried what I was doing to my rotors than my pads because I had to keep bedding them.
THEN... I got Hawk ceramic brake pads in the front (only). The squeal was GONE!!
Try it. First, it is not an expensive fix, even if you have someone else do it. Second, how long do you want to put up with your car sounding like crap stopping at a light!!
Old Jan 6, 2012 | 01:22 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
And what I meant by , was you paid enough for this car, you should not have to "GET USED TO IT"!!!!!
Old Jan 6, 2012 | 04:07 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
brettbolt,
Have you had a mechanic take a look at it?
Chevrolet Customer Service,
Justin
To Brake noise
