Replace Caliper Bolts?
Old Jan 9, 2012 | 01:19 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Replace Caliper Bolts?
C5 brake caliper mounting bracket bolts were supposed to be single-use, replace every time; but most people reused them with blue Loctite.
Looking in my Service Manual (2009 Z51) page 5-102, I see a similar warning.
The common explanation is that GM just doesn't trust everyone to properly clean the bolts and apply blue Loctite. If so, re-using with proper cleaning and Loctite is perfectly safe.
What do you think?
Old Jan 9, 2012 | 01:23 PM
fastter's Avatar
fastter
I replaced mine. I thought it was more than just a Loctite issue ... something about a taper? I might be wrong.
Old Jan 9, 2012 | 01:30 PM
JKbride's Avatar
JKbride
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
I have never replaced mine. When I remove the caliper I just reapply blue lock tight. I do the same for the caliper bracket bolts too, when I remove them.
As for the Brake Pins, which the caliper floats on, when I remove them, I wipe the grease off, inspect and reapply with high temp grease.
I suspect the replace caliper bolts is a CYA message from GM.
My .02 worth anyway.
Old Jan 9, 2012 | 03:47 PM
TMyers's Avatar
TMyers
I reuse them and don't use loctite. I have them off and on a few times a year and they have never been loose.
Old Jan 9, 2012 | 04:11 PM
masihman's Avatar
masihman
I've never used loctite on any caliper bolts either and have never had an issue.
Old Jan 9, 2012 | 04:13 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
I think I have done 5 or 7 rotor replacements and always reused, never an issue.
Old Jan 9, 2012 | 04:31 PM
wayback's Avatar
wayback
Never had a problem reusing mine.
Old Jan 9, 2012 | 04:51 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Yea you're s'posed to but I have always re-used mine + loctite.
Old Jan 10, 2012 | 06:03 PM
Gearhead Jim
St. Jude Donor '13
The local dealership could have made more money by selling bolts to everyone with a C5, but the tech reused them with Loctite.
Today I asked him about the C6, he says they are doing the same: clean and reuse with blue Loctite, unless there is some other problem.
Old Jan 10, 2012 | 06:24 PM
Don-Vette's Avatar
Don-Vette
What do you think?
I would not worry about it,I would reuse them,your explanation is plausible. I have machined plenty of bolts and screws and have never heard of any damage that would come by reuse.That said,if it was under a high torque condition,reuse could stretch the bolt threads causing failure.Which on a caliper you have no worries of that happening.
Old Jan 10, 2012 | 07:50 PM
toomuchcar's Avatar
toomuchcar
I reused my bolts. There is nothing wrong with those huge bolts that they need replacing.
Old Jan 10, 2012 | 08:17 PM
speedraider's Avatar
speedraider
same here
To Replace Caliper Bolts?
