This is what I was alluding to in another thread
Guys,
You are not seeing something...
At the smog test, they connect to your PCM via the OBD2 port and read these things (using Mode $09):
- CAL ID for each segment,
- CVN for each segment,
- VIN of your vehicle,
they then use the VIN to look up a database containing valid CAL ID and CVN values for your VIN (this is already in place for 2005+ cars);
the CVN's are like checksums; when tuning software writes to the PCM, the tuning software calculates what the CVN should be for each segment and writes it to the PCM; when you turn on the key, the PCM performs the same CVN calculation and expects to arrive at the same values;
if you have significant engine mods, you would have had your PCM tuned, which means the CVN for the engine segment now differs from original...
if you deleted codes, then the engine diagnostic segment CVN differs...
if you had your auto trans tuned, then the trans segment CVN differs...
if you changed your ring/pinion ratio, then your speedo segment CVN differs...
if you changed your fan on/off temperatures, then your system segment CVN differs...
[ if GM reflashed your PCM for some reason or other, CARB will know about it (since the PCM is an emissions device), and the new CAL ID and CVN will end up in the database ]
if your car is a 2005+ they will definitely see the differences in CVN values, and they will fail you;
if your car is 2000-2005 they may still be able to pick up on these differences, even tho they didn't legislate for a database for cars prior to 2005; that doesn't mean they don't have a means of looking up and checking (they have had the ability to store the CAL ID and CVN values from all your previous smog tests, and they have the computing ability to detect differences, they just can't necessarily compare them to the OEM values);
in short, this is looking bad.
Copied from another source
I also noticed that I posted in the wrong section, it belongs in off topic.
The Consigliere
Received 5,466 Likes
Boy, if we could just have more regulations the world would be grand, wouldn't it. . . . ?
