Problem: FOB Programming '07
I have a new FOB I want to add. I've tried the instructions in the manual and instructions found here on the forum. No matter what I do I can't get the DIC to display "Ready For FOB #X". With both the new and current FOB on my person, I use the trunk key to open the trunk. Then turn the key 5 times within 5 seconds.. nothing on the DIC. I've tried with the car completely off and in accessory mode. What am I missing here.. any tips or tricks to this?
11. Drivers window down, car off
12. Trunk open
13. Glove box open
14. Make sure NO Fobs are anywhere near the car. IMPORTANT.
15. Put key in trunk keyhole and turn key five times in less than 5 seconds.
12. Trunk open
13. Glove box open
If that's what you're doing, it's wrong. All FOB's have to be FAR AWAY from the car, outside the garage, farthest corner of the house or yard, whatever it takes. It's pretty amazing how far away they have to be considering all the threads we see about FOB's not being recognized even in the car due to RF interference, etc.
Your instructions are from the LONG procedure which erases existing FOBs. I'm just adding a FOB which is steps 1-10. Step 4 says keep the current FOB in the car as does the manual #2:
"Have the recognized and new, unrecognized trasmitters on your person."
Okay, then you are doing it correctly but......you understand that the new FOB won't have access to memory settings, etc using the short procedure.
That's fine I'm just trying to get the new FOB matched first. Then I'll do the long procedure.. I don't want to erase FOBs unless I know it can work.
Okay. Make sure you are turning the key a full 90 degrees. Frequently dirt in the lock prevents this. And if there's a backup camera mounted above the license plate, at least one member reported that it was preventing turning the key all the way.
Check these hints, posts #111 and #112 from the programming thread, might help.
http://forums.corvetteforum.com/1576835889-post111.html
http://forums.corvetteforum.com/1576835961-post112.html
A) I do not have the KEY for the new FOB, just the FOB itself. Do I need it in the FOB for it to work?
B) I insert it "key forward" with buttons pointing to the passenger side of the car.. it appears to "snap" into place.
Only thing I can think is that maybe the battery in the new FOB is dead or maybe it needs turned over (it's new from the dealer). Maybe they ship them upside down to prevent battery wear? Sounds stupid but it's all I can think of at this point.
Several members have reported difficulty getting their cars into program mode. I had difficulty getting mine to enter program mode, as well. In my case, it was due to slack in the lock cable not allowing the key to turn the mechanism far enough to close the electrical contact. I removed the carpet from around the lock and manually pushed the lock mechanism against the contact 5 times within the 5 seconds and immediately got the program mode message on the DIC. You might try this to see if it solves your problem. If not, the dealer can program your fobs using a Tech II scan tool.
You say above that you insert the new fob "key forward". It has to be inserted with the key end facing the rear of the car -- the lock/unlock buttons furthest forward -- and the buttons facing the passenger side. Or is that what you meant by "key forward"?
You nailed it. I was trying key end facing front. I tried it numerous ways but for some reason this time with key end facing to the rear, it finally worked.. I'm a happy guy and this forum rocks!
