Saving settings when removing battery
Old Jan 19, 2012 | 08:10 PM
FiremanC7's Avatar
FiremanC7
Default Saving settings when removing battery
I have searched many times, but can't find a post I saw several weeks ago. The post concerned using a 9 volt battery to maintain the system memory while removing the battery from the car. Can anyone point me in the right direction?
Thanks,
BobD
Old Jan 19, 2012 | 08:15 PM
RicK T's Avatar
RicK T
This one?
http://forums.corvetteforum.com/c6-c...codes-etc.html
Old Jan 19, 2012 | 08:33 PM
FiremanC7's Avatar
FiremanC7
Thank you! That's exactly what I'm looking for.
BobD
Old Jan 19, 2012 | 09:11 PM
LarryMJones's Avatar
LarryMJones
Veteran: National Guard
St. Jude Donor '13-'14-'15-'16-'17
They have one at Walmart for about $4.00. I noticed it today and started to buy it just to have ready if needed.
LJ
Old Jan 19, 2012 | 09:16 PM
luvlake's Avatar
luvlake
Last Friday, I replaced my 4.5 year old Delco with an Optima (Yellow Top). I had no problems. All I had to do was re index the windows and reset the clock and radio stations. Something else must be wrong. I spent most of my time trying to loosen the cables from the battery posts on the factory battery.
Old Jan 19, 2012 | 09:25 PM
EVRose's Avatar
EVRose
I did'nt loose anything but the widows. Clock and radio presets were all still correct.
Old Jan 19, 2012 | 10:33 PM
Grzldvt1's Avatar
Grzldvt1
Same here
Old Jan 20, 2012 | 02:37 PM
Xedes's Avatar
Xedes
Loose= not tight
Lose= lost
Sorry to be the grammar **** but it was bugging me.
Old Jan 20, 2012 | 03:34 PM
VET4LES's Avatar
VET4LES
Originally Posted by Grzldvt1
Same here
I disconnect my battery when on vacation and when I replaced it. I only re-index the windows. Nothing else changes.
Old Jan 20, 2012 | 03:36 PM
Vette_DD's Avatar
Vette_DD
That's the only thing most who have posted here have had to update/change, besides the clock (sometimes).
Old Jan 20, 2012 | 03:38 PM
PHXAZ06's Avatar
PHXAZ06
I also kept my gate and garage door programming.
Only had to do window indexing which is easy peasy....
Old Jan 20, 2012 | 03:42 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Reindexing the windows takes about 15 seconds and is all that is needed. Probably easier and quicker than finding a 9 volt battery.
Old Jan 20, 2012 | 07:00 PM
z06clif's Avatar
z06clif
me too
Clif
Old Jan 21, 2012 | 01:31 PM
REDJET94's Avatar
REDJET94
Just got a c6 3 weeks ago. Car is great and i'm learning new things about the car everyday. But what do you mean by re index the windows? thanks
Old Jan 21, 2012 | 09:33 PM
Jimsan's Avatar
Jimsan
Old Jan 22, 2012 | 02:26 PM
jedblanks's Avatar
jedblanks
Since the windows are auto up and they "index" down when opening the door, the car has to relearn the top position of the window. This is done by fully raising the window and holding up for 3 seconds twice
Old Jan 22, 2012 | 04:45 PM
JCtx's Avatar
JCtx
With door open or closed? . And drove an '12 GS the other day, and windows only had auto-down, not up. But it was a 2LT. Maybe 3/4LTs have auto-up as well.
To Saving settings when removing battery
