Window Close when Door Closes
I had my battery replaced last week and since then when I close the drivers door, the window does not come up. It drops the 1/2" when I open the door, but doesn't go back up.
Is there some sort of reset required?
Thanks in advance.
Thanks in advance.
2016 Corvette of Year
2015 C6 of Year Finalist
you need to re index the windows
close door, have accessory mode on, hold both window swithces up for 3 seconds, release and then hold up again fro 3 seconds
Clif
Close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Don't forget the other window.
Interesting that I had to reset the indexing on the windows...didn't lose any radio or NAV data but did lose the window indexing.
It will need to be reset every time you disconnect, then reconnect the car battery.
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Don't really understand that about losing the window indexing, but literally hundreds here have found it to be true. With only a very rare exception, most who did and posted here lost only the window indexing.
with all above.
