Rain
Old Jan 25, 2012 | 11:50 AM
dazz44's Avatar
dazz44
Default Rain
Every time it's rain my service active handle system comes on. Should i worry are take it in to service? When I restart it light goes out. Can someone help with this problem or is this a problem.
Old Jan 25, 2012 | 11:56 AM
Jimmy W1's Avatar
Jimmy W1
I would say that the computer is sensing the moisture and kicking on the light. And when you turn it off and restart it- the computer is resetting itself. I would ask the dealer the next time you are there. Or you might have someone check it out with the readout computer.
Old Jan 25, 2012 | 12:04 PM
LS WON's Avatar
LS WON
Ever get the "Recalibrating" signal?
Old Jan 25, 2012 | 12:10 PM
cclive's Avatar
cclive
It might be that water is getting into the speed sensor connection at one of the wheels. Reading the code that is generated should tell you which wheel.
Old Jan 25, 2012 | 04:03 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Yes, you should worry.
Usually, a Service Active Handling light will simply put the system out of action. But there have been situations where it went goofy and hit just one brake for no reason with no warning.
Until you get it fixed, best bet would be to turn the system off each time you start the engine, and drive more carefully.
Good luck with yours!
Old Jan 25, 2012 | 04:44 PM
dvilin's Avatar
dvilin
I would get it checked out.
Old Jan 25, 2012 | 06:38 PM
Vette5.5's Avatar
Vette5.5
I agree on definitely getting the system checked out, as I've gotten caught in some pretty bad rain storms, and never had that happen.
Old Jan 25, 2012 | 07:56 PM
dazz44's Avatar
dazz44
Taking it in Thrusday morning!! Thanks Guys
Old Jan 25, 2012 | 08:21 PM
Goatdad's Avatar
Goatdad
St. Jude Donor '11-'12-'13
Good luck.
Please keep us posted on the outcome.
Old Jan 25, 2012 | 08:32 PM
Marc V.'s Avatar
Marc V.
Where are the forum members who will flame you for taking it out in the rain?
Old Jan 26, 2012 | 09:52 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
dazz44,
Hello, I am new to the forum my name is Evan; I have been assigned to work on this forum. Dazz44 keep us updated on what you find out at the dealer! Good luck!
Evan, Chevrolet Customer Service
Old Jan 26, 2012 | 10:11 AM
SilverScorp's Avatar
SilverScorp
I've driven mine in some brutal thunderstorms and have never had that happen. Something is wrong. Get it checked out asap.
Old Feb 17, 2012 | 07:34 PM
SnowyATX's Avatar
SnowyATX
Any update?
Old Feb 17, 2012 | 07:38 PM
Radioman's Avatar
Radioman
Old Feb 17, 2012 | 08:20 PM
OnPoint's Avatar
OnPoint
The Consigliere
Old Feb 17, 2012 | 08:40 PM
dazz44's Avatar
dazz44
Originally Posted by MachSilver08
Any update?
Just got it back from dealer...it was the sensor in the steering wheel. The reason I thought it was the rain was because it only happen when it rain. I guess I was wrong!!!!
Old Feb 17, 2012 | 08:45 PM
OnPoint's Avatar
OnPoint
The Consigliere
Glad you got it fixed. Maybe need to drive it in the rain again just to make sure.
To Rain
Old Feb 18, 2012 | 12:18 AM
teenVette's Avatar
teenVette
Veteran: National Guard
Old Feb 18, 2012 | 08:23 AM
STONEFLYE's Avatar
STONEFLYE
Rain???
Old Feb 18, 2012 | 09:49 AM
JScottH3's Avatar
JScottH3
The only time I've had it happen was right after refilling the windshield washer tank (OK, I spilled a little). I drove about 2 miles to the store, and when I restarted it didn't show up again. Haven't seen it since. I just figured that I spilled some fluid on a sensor and it dried up by the time I restarted. And yes, it's my DD, so it gets driven in the rain...
