Broken lower radiator support bracket
Old Jan 30, 2012 | 09:13 PM
shelleygraham's Avatar
shelleygraham
Default Broken lower radiator support bracket
When turning or going over a high spot in road I hear metal scraping underneath drivers side. I looked underneath and there is something metal all scraped up. The dealer said it was a metal strap and they "put it back up". What is this metal piece and does the lower radiator support bracket hold this in place ? I was told by someone else the lower radiator support bracket is broke. The dealer didnt see this they just put back the metal strap !
Old Jan 30, 2012 | 10:35 PM
DSOMC6's Avatar
DSOMC6
Do you happen to have a picture you could post? It appears you are correct because the only metal piece (black,about 1'x1" in diameter) that extends below the front bumper cover is the lower rad support. If that's the case, your dealer doesn't care or is a dumb a$$.
Driving with a broken rad support, especially on the passenger side, can cause the radiator to drop just enough and rest on the lower tranny fluid line that routes to the radiator for cooling (if so equipped). This often results in a cracked line, leaking tranny fluid and possibly tranny damage (no low tranny fluid message will display on dic btw). Least case, it's a huge pia changing the hard line.
Post a pic or get someone knowlegable to look at it.
Old Jul 31, 2018 | 07:22 PM
Mark257wm's Avatar
Mark257wm
2nd Gear
I just ran into the same issue, only thing is, I just bought the car, first corvette and only second car I’ve ever owned. And learned a valuable lesson. Luckily I like tinkering with cars and there’s YouTube, was able to remove and took to a busy to have welded. As soon as paint dry sill reinstall.
Old Aug 1, 2018 | 03:26 PM
nick14003's Avatar
nick14003
have you been love tapping parking concrete blocks?
If so, the lower radiator support is raped.
It's made out of aluminum for weight purposes so it is very weak.
Option 1, slightly damaged, have an aluminum brazer fix it. $1-300.
Option 2, beyond recovery, replace support $300-600.
I replaced mine myself, found one for ~$300.
Old Aug 1, 2018 | 03:40 PM
EVRose's Avatar
EVRose
This thread is over 6 years old.
Old Aug 4, 2018 | 02:47 PM
nick14003's Avatar
nick14003
lmfao why would someone bring this up... i didnt even check the dates
Old Aug 4, 2018 | 11:12 PM
buckmeister2's Avatar
buckmeister2
Because EV likes short answers...
Old Aug 5, 2018 | 10:02 PM
Mark257wm's Avatar
Mark257wm
2nd Gear
Because they have nothing better to do. Haha! I’ve gotten good information from old blogs
To Broken lower radiator support bracket
