Cabin Air Filter
Old Feb 1, 2012 | 08:42 PM
markzeronine's Avatar
markzeronine
I forgot about mine, it needs to be changed. Gives me something to do tomorrow!
Old Feb 1, 2012 | 09:10 PM
The_Tibulator's Avatar
The_Tibulator
Originally Posted by TNTC4VETTE
I can't get my new one to fit!
I crammed the new one in there..hope it's right!
Old Feb 1, 2012 | 09:21 PM
cclive's Avatar
cclive
Push it in by the sides, the center tends to collapse.
Old Feb 1, 2012 | 11:08 PM
JKbride's Avatar
JKbride
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
Got mine today and will put in this weekend. Got the Purolator at Pep boys for $12
Old Feb 2, 2012 | 06:51 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Once the sides start folding it is only going to get harder. I finally used a couple of small plastic rods to push on the inside corners so the filter was essentially pulled into the slot rather than pushed.
Old Feb 2, 2012 | 10:54 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
On our 2009, the tracks that the filter slides into, on each side of the housing, are slightly curved. If you use a flashlight and look carefully when the filter is removed, you can see what i mean. I had to angle slightly downward while inserting the filter, as well as pushing inward.
Old Feb 2, 2012 | 11:28 AM
Jimsan's Avatar
Jimsan
Originally Posted by KenHorse
Unless the source is sitting in one of the seats....
Yeah,that's why they have windows
Old Feb 2, 2012 | 11:33 AM
Jimmy W1's Avatar
Jimmy W1
Originally Posted by gilhuly
wait,......is that a Cheetos in that filter?
It sure looks like it. I find them under my couch cushions all the time. They should be good to eat up to three weeks.........
Old Feb 2, 2012 | 11:40 AM
cclive's Avatar
cclive
Mine wasn't that tight, but that's a great idea if it is.
Old Feb 2, 2012 | 12:01 PM
08VRZ06's Avatar
08VRZ06
Cruise-In X Veteran
That is the one that I used in mine.. Purolator C25623......... It is also a carbon one!!
Mark
Old Feb 2, 2012 | 12:35 PM
nmerhaut's Avatar
nmerhaut
Can these be vacuumed out or is that not a good idea. This filter isn't black looking just dusty with a few food morsels.
Old Feb 2, 2012 | 12:43 PM
cclive's Avatar
cclive
For $13 at Pep Boys, I would just replace it. Also it is probably a little tough to get the vacuum down into the folds.
Old Feb 2, 2012 | 12:57 PM
  #33
nmerhaut's Avatar
nmerhaut
Good point. I was thinking of the "infamous" crevice tool.
Old Feb 2, 2012 | 01:08 PM
  #34
Topsarge12R's Avatar
Topsarge12R
I checked mine at around the same mileage. Mine was just plain nasty! Replaced.
Old Feb 2, 2012 | 02:31 PM
  #35
Tikiman12's Avatar
Tikiman12
Better then what my looked like.
Changed it at 60k miles
Old Feb 2, 2012 | 03:40 PM
  #36
LS WON's Avatar
LS WON
Old Feb 2, 2012 | 03:44 PM
  #37
Gering's Avatar
Gering
Tolero Apto Victum
Originally Posted by abstruse1
Cabin air filters are also available with activated carbon. Helps eliminate some of the odors that can plague these cars.
They work well.
To Cabin Air Filter
Old Feb 2, 2012 | 03:58 PM
  #38
Eran X. Jones's Avatar
Eran X. Jones
Default Cabin Filter/Intake Filters
I change the ones in my Wife's C6 every January when it is due for inspection. Just a habit I got into doing for her.
Old Feb 2, 2012 | 04:08 PM
  #39
orca1946's Avatar
orca1946
I just found pep boys locally & will get one tomorrow!!
Old Feb 2, 2012 | 04:21 PM
  #40
FortMorganAl
Your old one shows the kind of folding I talked about that even the factory does. You can see a couple of large folds in the sides in the center top and, if you look closely, there are smaller folds all along the top and bottom sides. Hold a ruler up to the monitor and you can tell the old filter is significantly narrower than the new one. It looks to me like about 2 to 4 pleats on the new one. That is how much open space there was (or more) when the old one was installed.
