Oil Temperature Sender/Sensor
Old Feb 6, 2012 | 07:21 PM
Ahmer's Avatar
Ahmer
Default Oil Temperature Sender/Sensor
Anyone know where this is located? I think mine needs replacement.
I can DIY this, I hope.
Old Feb 6, 2012 | 07:35 PM
Ahmer's Avatar
Ahmer
Is it above the oil filter like the c5??
Old Feb 6, 2012 | 07:49 PM
cajun man 08's Avatar
cajun man 08
Had change mine recently,it is located under the manifold near the firewall.Dealer wanted about 600.00 to replaced,looked in search section for DIY repair a took about 30 min.Cost about 50.00.
Old Feb 6, 2012 | 07:52 PM
cajun man 08
Just reread thread temp sensor is on left side front.
Old Feb 6, 2012 | 08:16 PM
Ahmer's Avatar
Ahmer
Next to firewall... near exhaust manifold???
Also can i buy this from autozone?
Old Feb 7, 2012 | 08:11 AM
Ahmer's Avatar
Ahmer
Anyonr?
Old Feb 7, 2012 | 09:07 AM
Ahmer's Avatar
Ahmer
Ok searched around here on the forums and it seems like the oil temperature sensor is integrated with the oil "LEVEL" sensor located on the bottom of the engine oil pan...
So... this means I need to drain oil, change sensor... replug, refill???
Any insight on this would be greatly appreciated.
Old Feb 7, 2012 | 08:20 PM
Ahmer's Avatar
Ahmer
I found these two:
http://www.partsgeek.com/gbproducts/...06&fp=pp&gbm=a
http://info.rockauto.com/getimage/ge...tex/5S8223.jpg
Can someone confirm which is the correct part???
Old Feb 7, 2012 | 08:57 PM
scootertrash19's Avatar
scootertrash19
Originally Posted by Ahmer
The rock auto part looks closer to factory than the other one, do a search in the performance/tech area for Oil temp sensor and go to post #14 there is a pictures of the sensor in the side of the pan, it looks like the rock auto part, but kind of hard to tell without seeing the whole part. You may want to buy one from the dealer, just to be sure it's correct, Good Luck
Old Feb 7, 2012 | 11:37 PM
vetteright's Avatar
vetteright
Why not get a quote from Gene Culley at GM PartsHouse or Kevin Cassimore at PartsTaxi, both forum vendors, for the factory GM OEM part? Both of 'em have good pricing and great service.
Old Feb 8, 2012 | 08:33 AM
Ahmer's Avatar
Ahmer
Ok will DO! Although the Rock Auto part is rather tempting...
$32 SHIPPED.
Old Feb 11, 2012 | 06:31 PM
Ahmer's Avatar
Ahmer
Got the part... its got a strange hard plastic end which kind of looks lke foam... im guessing this is what "floats" in the oil...
Where is the thermometer in this thing???
Old Feb 12, 2012 | 08:39 AM
cajun man 08
Default oil temp sensor
If it has a small hole in the end it's the pressure sensor,i think the temp sesnor has a metal end.
Old Feb 12, 2012 | 08:51 AM
lastcowboy's Avatar
lastcowboy
should be d.side rear ,under v.cover near f. wall depending on the motor
Old Feb 12, 2012 | 11:00 AM
Kenny94945's Avatar
Kenny94945
The Oil Pressure Sensor...
is near the upper firewall on the driver's side of the engine block.
Only need to remove the valve cover plastic cover to remove and have a sensor installation socket.
The Oil Level Sensor...
also measures the temp.
This sensor is located on the oil pan under the starter.
Advised to drain oil before replacing.
To Oil Temperature Sender/Sensor
