Locked in
Old Feb 9, 2012 | 10:19 AM
martinf55's Avatar
martinf55
Default Locked in
Go out to start my car the other day while it's sleeping for the winter. Shut it down, push the button to open the door...nothing happens, the door won't open. I had to push the door locks button first, then I was able to open the door and get out. Never happened before but now it still does this.
Old Feb 9, 2012 | 10:26 AM
Landru's Avatar
Landru
First-off, are you on a battery tender?
Old Feb 9, 2012 | 10:27 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
How long has it been sleeping? What year? How is it sleeping in regards to battery charge? Do you have a tender on?
Old Feb 9, 2012 | 10:31 AM
martinf55's Avatar
martinf55
2007-Yes, I do have a battery tender and I start it once a month. New battery this past summer and this is what I've been doing the past 4 winters and never had a problem.
Old Feb 9, 2012 | 10:40 AM
Landru's Avatar
Landru
First thing to do, disconnect the battery. After a few minutes, reconnect. Force the ECM to reboot.
IF any data whatsoever decayed due to prolonged inactivity? An ECM (computer) behaves very weird. Rebooting's solved a LOT of very strange stuff with the C6. Try it, it's the least expensive first step towards troubleshooting this issue.
Old Feb 9, 2012 | 10:43 AM
2vettes's Avatar
2vettes
You do know, I trust, that the fob battery needs to get replaced on average every 3 years; some last longer, some last less. Walgreens pharmacy stocks them; very inexpensive.
You also know about the emergency door release lever on the floor between the door and the seat, don't you?
Old Feb 9, 2012 | 10:46 AM
6spdC6's Avatar
6spdC6
Interesting between my 05 I had and now the 07 never had a problem like that. I do not start my car; it is sitting in garage tender on from Nov- late March.
Possibly you just have an electronic hiccup. The best and cheapest attempt fix is to disconnect battery wait a few minutes and rehook. Sometimes that acts as a reboot. I would do that only after I knew my battery was up on full charge to begin with!
FWIW my 05 was a well know DBS car but that was a different battery type problem. That taught me to always leave it in garage with a window down under car cover so I could get in easy in case another DBS issue occurred.
Old Feb 9, 2012 | 11:52 AM
martinf55's Avatar
martinf55
Fob battery was replaced and I'm aware of the emergency door release
Old Feb 9, 2012 | 11:54 AM
martinf55's Avatar
martinf55
The problem is getting OUT not IN
Old Feb 9, 2012 | 11:55 AM
martinf55's Avatar
martinf55
Do I disconnect positive or negative side?
Old Feb 9, 2012 | 12:14 PM
Landru's Avatar
Landru
Negative.
Again, wait a few minutes alllowing computer memory clear (discharge). Reconnecting automatically reloads programming.
I suspect, and hope, your problem evaporates.
Let us know if it did/didn't rectify the problem(s). *Must* rule-out what it isn't, first.
Old Feb 9, 2012 | 12:20 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
I'm having a problem with the FOB's opening the doors. New batteries in the FOB's and a brand new car battery. The door lights blink, but the door will not open unless several attempts are made. Any ideas ? Mine is an 2008 standard coupe.
Old Feb 9, 2012 | 12:32 PM
Landru's Avatar
Landru
Does ths happen with BOTH doors? How about opeing manually, visa vi the touch pad(s)?
IF it's happens with only ONE door manually? Sounds *like* a defective touch pad. Easy check for this is swapping driver's & passenger door pads. Two screws remove each. Swap & reattach.
IF it's a bad touch pad replacments are easily attainable & among the least expensive fixes on a Corvette.
Old Feb 9, 2012 | 12:33 PM
6spdC6's Avatar
6spdC6
I know that. Any type gremlin is possible so by leaving a window down IF a entry problem occurs you can get in easy without using the trunk/hatch key. Just passing that on to the troops here!
I had to get out a couple times by hitting the inside release, like I said I had two years of battery type problems and saw/learned a lot.
Old Feb 9, 2012 | 01:13 PM
mikejpss's Avatar
mikejpss
Its with BOTH pads. They were changed out once already. I DID find in another thread, that I replaced my batts in the FOB with Ray O Vacs (no-no) so will try a different brand later today. Thanks for your input.
Old Feb 9, 2012 | 01:22 PM
2vettes's Avatar
2vettes
Old Feb 9, 2012 | 01:34 PM
Landru's Avatar
Landru
OK, scratch that.
Really. A no-no, wonder why.
Sounds like a plan in any event, let us know if rectifie's the issue.
Old Feb 9, 2012 | 03:41 PM
mikejpss's Avatar
mikejpss
By searching the threads here on C6, I learned that a Ray-O-Vac battery has a raised surface (checkering) on one side. THAT is suppose to be a bad thing for our FOB's.
I just bought 2 new EverReady batts, it appears to have helped opening the doors, but the passenger door is still not 100%. Guess that doors keypad is faulty -again. I have replaced both sides once already. Do they make a Made in USA pad ? The original and the replacements were made in Mexico.
Old Feb 9, 2012 | 04:28 PM
JoesC5's Avatar
JoesC5
Ever so often I have to push the door unlock button and then the door open button works. To me it's not a big deal, so I haven't tried to find out under what conditions causes it to happen.
To Locked in
