C6 Lust
I seem to have developed an unnatural desire to buy a C6, but have absolutely no experience or familiarity with C6's, so I have lots of newbie questions.
My uneducated preference at this time is the 6 speed manual, but have some concerns. First, I live in the SFV (LA) area and traffic is a biitch. Secondly, for the sake of discussion, let us assume that most C6's have been driven enthusiastically. What is the point of owning a hi performance car if one doesn't put ones foot in it now and then? It would seem logical that manual transmission cars may have been driven more enthusiastically than the automatics. I am quite concerned about buying some PO's problems. What is the life expectancy of the C6's clutch and how costly is it to have it replaced if/when needed? How bullet proof are the automatics?
What it the most common drive train failure in the C6's, both manual and automatic?
In that same vein, what are the most common failures of any kind on the C6's?
Your comments and suggestions will be most appreciated. Thanks
Larry
Larry
There are a lot of low mile C6s out there, so find one of those and worry not about life of clutch etc. Just get a clean, garage queen, low mile C6 and then drive it. They are pretty robust cars - especially for sports cars.
WARNING! The price you pay for the car is only the begining. Your customization will never be done.
packages & configurations. That will help you in scoping-out which features are more/less important to you...
Get the automatic! It has paddle shifters, so you can select & hold gears... 09 and newer automatic-C6's even blip the throttle for smooth downshifts.
The auto in my C6 is by far the best I've ever had. And it's very popular... 69% of C6 coupes/verts have it.
Problem area: Some reports of damaged auto-shifters. Long-story-short, I think most of this is caused by someone mistakenly forcing the shifter.
And sometimes the auto trans seems to misbehave:
http://forums.corvetteforum.com/c6-t...blem-help.html
http://forums.corvetteforum.com/c6-c...esitation.html
On the other hand... I'd expect the manual trans is more fun & more involving.
Used-Car Tip: Dirty clutch fluid can cause a sticky clutch pedal and shifting issues. An unknowledgable owner might think there's an expensive problem. DIY fix with new fluid & flush: http://www.youtube.com/watch?v=gBbsy0LjUvE
An unknowledgable owner might also be inexperienced... an expensive learning curve of botched shifts, excessive clutch slippage, high-power experimenting, power shifting, etc.
The-Usual-Advice:
-- Get the newest C6 you can afford.
-- Like any used car, do your due diligence (inspection, history, etc etc)
Enjoy your search!
Good luck and welcome to the best forum for vettes.
Man can I relate. I come from a 65 L-79 vette a while ago. I got the bug and like you went looking for a gently used GS. I got lucky over your way (Corvette Mike) and just took delivery here in Phoenix. It is a M6 with only 3K miles and I love it. I went with a highly optioned one (3LT with Nav) which is personal preference. I would not hesitate to jump at a low mileage C6 as has been stated above. Your near the end of the C6 run which to my way of thinking is a good thing.
Good luck on your search.
Cheers,
Bill in Phx
The auto is a outstanding option offered on the later model C6. No knock on the manual as that is a lot of fun also. But, heavy traffic forget about it.
I go to LA a lot on business and I'd get an automatic there given the traffic. Even if a weekend car, getting through that traffic to open road might be real chore. If an auto, you'll enjoy using it more often.
Go for it.
you are in for a treat, the C6 is a great car. good luck with whatever you decide and keep us up to speed....
