Driver seat bottom
Old Feb 12, 2012 | 08:58 PM
eight3two's Avatar
eight3two
Default Driver seat bottom
Does anyone else feel like there is something mounted under the left side of the driver seat that you can feel when the seat is adjusted all the way to the lowest position (and slightly above the lowest setting)?
It's almost like theres something about the size of an amp or module of some kind that i'm sure i can feel on left left *** cheek bone.
Anyone else notice this? Any idea what it is without pulling the seat out to check it out?
In an 09 3lz z06 if that matters.
Old Feb 12, 2012 | 09:09 PM
z edge's Avatar
z edge
is it the power seat motor?
Old Feb 12, 2012 | 09:16 PM
eight3two's Avatar
eight3two
Power seat motor, bose amp, or something to do with onstar/xm...that's be my guess at least.
I'm less concerned with what it is (bc i know its there) but rather if others have had similar experience with it being in the way when the seat is in the fully lowered down (closest to the floor) position. And if so what was done, if anything, to remedy it. Or if mine is the only one.
Old Feb 12, 2012 | 09:27 PM
ch47d1sg's Avatar
ch47d1sg
There is a seat cusion mod the can be done to firm the seat prevents the sag... Order from Westcoast corvettes. I hae done that and a couple of other mods to make the seats better
Good luck
Old Feb 12, 2012 | 09:30 PM
Bill Dearborn's Avatar
Bill Dearborn
It is the seat memory module. Here is a picture. It is the big black box above the motor.
The module is clipped to the seat springs. When the seat is down all the way the module/wires and seat motor all try to fit into the same place and the module being clipped to the springs moves upwards just a bit. You can make more room by installing the seat mod which adds some extra firm foam along the sides of the seat bottom foam and a piece of jute padding between the seat bottom foam and the springs.
I have to remove the module every time I switch to my race seat since it controls the telescopic wheel and has to be in the car.
Bill
Old Feb 12, 2012 | 09:46 PM
eight3two's Avatar
eight3two
Perfect. Thanks Bill.
I assume the module cant just be relocated to a 'better' location under the seat?
Do you have a link where i can buy the the 'seat mod' firm foam? How difficult is the removal of the bottom seat skin?
Old Feb 12, 2012 | 09:55 PM
Bill Dearborn
Seat skin isn't that hard to remove. It is fastened in with hog rings but when I reinstalled it I used the plastic wire ties that were in the kit.
Here is a link to a web site that has the kit for sale. This isn't a recommendation you buy it from this forum vendor. There are several forum vendors that sell it so go with the one you like the best.
http://www.westcoastcorvette.com/p-3...2-c5c6z06.aspx
The stock foam tends to slide down along the sides of the frame so the added foam fills the space that it would fall into. If your seat foam has done that then this will push it back up and smooth out the wrinkles in the seat bottom bolster.
Bill
Old Feb 12, 2012 | 10:03 PM
Just Buy It's Avatar
Just Buy It
The more "features" the more issues there are. Thats why I bought the LT-2 package. I want to push my 2012 Explorer off a bridge due to the Ford Sync package that does not work right. Keep it simple. Memory seats? Really? Who cares if you are the only one that drives it.
Old Feb 12, 2012 | 10:04 PM
eight3two's Avatar
eight3two
Bill help, Bill. Appreciate it!
Old Feb 12, 2012 | 10:10 PM
CO Lightfoot's Avatar
CO Lightfoot
This is a no-brainer... absolutely, get the kit! Available from many vendors, $40 + shipping. Includes xlnt DIY instructions.
For me, the most difficult parts of the install were figuring out how to disconnect the wiring harnesses (do NOT pull/force them) and removing the seat recline lever. It's all do-able; but like any project, there's a learning curve.
Or any decent car upholstery shop should be able to do the install.
Better yet, there's a forum vendor in Austin that can do it for you:
http://forums.corvetteforum.com/c6-c...tallation.html
If you need new foam, OEM replacements are available from forum vendors gmpartshouse.com or partstaxi.com. Upgraded foam is also available: http://forums.corvetteforum.com/c6-c...9-shipped.html
Also, as long as your seat is out & apart, if your leather is damaged you might want new seat covers (pricey but might be worth it to you).
Anyway, do some research before you buy.
http://forums.corvetteforum.com/c6-c...eat-cover.html
http://forums.corvetteforum.com/c6-c...post1579697744
Old Feb 12, 2012 | 10:15 PM
kevakasper's Avatar
kevakasper
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
I installed my kit today, took me about an hour.
Old Feb 12, 2012 | 10:18 PM
eight3two's Avatar
eight3two
Whats the verdict Kevakasper? Worth it?
Old Feb 12, 2012 | 10:26 PM
kevakasper's Avatar
kevakasper
The foam breaks down on the bolster area, and in the center as there is a grid of sharp wires that support the foam. The kit adds a nylon fabric to the bottom of the foam to repair and prevent the wire from cutting into the foam any more. They also include a piece of jute to help pad the wire grid. I installed the Jute as the instructions said it firmed up the seat. That was worth it. The other foam blocks install on the frame and under the foam bolsters. This adds support and height back to the bolsters. The answer is yes. Well thought out and complete. Worth $40.00 I don't know, but convienent for sure. Seat feels great, and mine wasn't too bad in the first place.
Old Feb 12, 2012 | 10:29 PM
eight3two's Avatar
eight3two
I'm gonna go ahead and order it. Thanks, guys.
Old Feb 13, 2012 | 12:50 AM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
Here is what is under your driver's side seat (2010).
To Driver seat bottom
