I have recently purchased a stock 2005 base coupe. The coolant temp in normal driving ranges from 195 to 205 degrees. It tends to rise even higher when stopped at idle. I'm not sure what the stock thermostat is but this seems high to me. Is this normal or could I have a fan problem.
Perfectly normal. The fans are set to be full on at ~234* Comparison:
My 2009 CTS runs at a constant 210* as does my Silverado. Both will creep up a tad in very slow traffic on a hot day.
That said, many (including me) have installed 160* thermostats and had the fans tuned to start at ~190*. Some just like to be cool!
My oem 2008 coupe runs 190 to 196 on the freeway and will run up to 220 in city driving. The fan will kick in at about 220 keeping the temps down below 220.
The oem thermostat for an 08 is 187, some have changed to a 160, but you should reprogram the fan to kick in sooner.
Thanks, I guess mine is normal. I think the higher stock thermostat is an EPA thing to help burn the polutants but around here the outside temp is reguarly over 100 degrees in the summer. 160 thermostat seems the way to go.
Those are normal temps for stock thermostat and stock fan settings.
Normal, in addition to the 160 and fan tune, I found two bottles of Purple Ice with a 70/30 (70 water/30 Dexcool) mix lowered it a little more. I dont know what state your in but if not in a time zone that has freezing 70/30 works well, water dissipates heat better than straight coolant.
How do you reprogram fan settings. Is it set by the computer. I wouldn't mind if the fan ran whenever the engine ran. I just want to be sure I never over temp the engine. I'm sure that would not be good for an aluminum engine.
sounds quite normal, do you hear the fan come on when the temp rises, I know that mine does
You will be fine with the stock thermostat. We had 71 days over 100 degrees last summer and I never had an issue. Find something else to worry about
My only concern was yesterday while driving the HUD coolant temp bar was almost to the top. There are no numbers just a bar. I called up the digital display and it said 205 degrees. I didn't know if that was high but after these posts here I am now satisfied it's normal. But I would like it to be lower.
Keep in mind that a lower temp thermostat will only keep your temps lower if the radiator is oversized. The stock stat is fully open at about 190, anything above about 195 is a radiator "problem" rather than a thermostat problem.
Corvette engines are lasting over 200,000 miles with the stock thermostat and radiator, I'd just keep everything in good condition and keep an eye on the water temp to spot any problems early.
Your car is engineered to accommodate a wide range of ambient (surrounding) temperatures. Changing your thermostat to a lower opening temperature will only increase fuel consumption and engine wear, as well as pollute the atmosphere, and won't do a damn thing to improve performance. GM engineers have forgotten more than your average shade tree, "Joe-six pack", Corvette owner will ever know about cars. But it is a undeniable right of Corvette owners to screw them up royally, which is one good reason never to buy a used Corvette that has been modified in any way.
I gotta tell ya, I bought an 06 over a year ago. My temp was running between 200 and 210 when I got it. It was about 200 on the highway and about 210 or higher in traffic.
I wanted the oil changed and the radiator flushed and I took it to a stealership of all places. They did a power flush and charged me $129.
The difference was pretty startling. I immediately noticed I was running between 190 and 200. Now, it never gets above 200.
In previous cars, I have always just drained the coolant and replaced it. But for some reason, since it was my first oil change, I took it to the nearest Chevy dealer. I also wanted to learn some of the ins and outs of the car and check the GM repair history on the car and see if there was anything that didn't turn up in Carfax.
I paid for the power flush, which apparently involves more than just draining and refilling and glad I did. It's a noticeable difference.
I posted this earlier and one forum member suggested the power flushing may have dislodged something that was blocking the system somewhat. Not sure what it did, but it works.
Also, I'm not sure what coolant was in there previously.
Fairly sure every time zone has freezing temps if you go far enough North.
I think this thread shows why most cars today don't have guages.
True but I love to watch mine!
I do a pre check of everything at start up, them monitor coolant and oil till warmed up.
I am a numbers guy and like the numbers more than the green,yellow and red level indicators.
I even try and guess were my numbers might be at any particular moment while driving, be it oil or coolant temperature, tire pressure or instant fuel mileage.
Ya I know get a life. I just have always enjoyed things this way.
