Quick hood question
Feb 23, 2012 | 12:59 AM
Quick hood question
So i am curious but will the RPO code B92 - HOOD CARBON FIBER option from gm fit on the standard base c6 model or not due to bumper
thanks
Feb 23, 2012 | 07:44 PM
St. Jude Donor '13 thru '20,'22,'24 thru '26
Feb 23, 2012 | 08:01 PM
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As noted, it will fit fine. Any hood from any C6 will fit on any other C6.
Feb 23, 2012 | 08:35 PM
Quote:
Originally Posted by
talon90
Excepting, of course, the ZR1 . . . . .
Feb 23, 2012 | 08:36 PM
NCM Ambassador
michaelinmech
Including the ZR1. They are all the same width and length and all share the same mounting points.
Feb 24, 2012 | 12:52 AM
talon90
Ummmmmm . . . I believe the under-hood supercharger and it's surround will not allow the ZR1 to accept any other C6 hood - so not all the same
Feb 24, 2012 | 01:11 AM
michaelinmech
He's talking about fitting it to a 'STANDARD BASE C6 MODEL'
. Not the other way around.
Feb 24, 2012 | 01:21 AM
ELP_JC
I understand the OP's question just fine.
I was respectfully responding to Talon90's reply that "Any hood from any C6 will fit on any other C6".
Feb 24, 2012 | 01:35 AM
St. Jude Donor '11-'12-'13-'14-'15
They will all 'fit' the car, they may not clear a motor with a supercharger though.
Unless you break out the saw.
Feb 24, 2012 | 06:34 AM
NCM Ambassador
michaelinmech
You are correct. The height of the standard C6 hood will not clear the intercooler for the ZR1 supercharger, that's why they had to add the window.
I just wasn't thinking in those terms as the OP had asked about the base but you're right, I had overlooked the height on the ZR1.
