Automatic Climate Control
Old Feb 24, 2012 | 09:44 PM
brianc6z16's Avatar
brianc6z16
Originally Posted by calemasters
If the above does not work, try to reset the HVAC control.
Press and hold these 3 buttons for 5 seconds with the ignition on, engine off:
  • Front Defrost
  • Rear Defog
  • Fan Up
OK, how do you have the ignition on and the engine off? Do you mean accessory mode?
Old Feb 25, 2012 | 09:27 AM
haljensen's Avatar
haljensen
Originally Posted by dardenken
???? When it is a little cold down here,i just turn the **** to 90 degrees and the heat comes from the floor vents.Thats the way it should work on AUTO.And do what post 12 said because the sensor is up front somewhere & I'm thinking it might get dirty.I've done that a few times & the temp resets.
The sensor that's "up front' doesn't control the HVAC, it only reports outside temps. The inside the cabin sensors determine how much heated or cooled air is delivered in the cabin per your setting for desired temperature.
Old Feb 25, 2012 | 09:53 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Push the bottom of the ign switch as if going into Accessory, but hold for 5 seconds (seems like 10).
Everything will power up (fuel pump, headlights if dark, etc) but the engine doesn't start.
Old Feb 25, 2012 | 11:36 AM
Cherokee Nation's Avatar
Cherokee Nation
Yes:I know that.I meant the sensor behind the front bumper sets the out side temp.The sensor that controls the cabin temp is right below the steering wheel on the right.
Old Feb 26, 2012 | 01:02 AM
JCtx's Avatar
JCtx
Simple.the buttom next to the AUTO.
That's the 'recirc' button man. Just received my documents and manuals, and this HVAC, although the ugliest I've had, it's the best . To turn the system off, you just push the temperature selector. And that works for the passenger side too. And best of all, besides being able to change from fresh to recirc mode with HVAC off (like most systems, except BMW), you can also change the temperature. Nice.
Old Feb 26, 2012 | 11:12 AM
Cherokee Nation
My mistate,It's the 3rd button from the right according to the manual
Old Feb 26, 2012 | 01:54 PM
Dif's Avatar
Dif
Originally Posted by TheShape8787
Kind of hard to explain this, but I think I have a problem with my climate control system. Whenever I turn on my heaters, all I get is constant coolish warm air coming out of the vents. The temperature settings between 61 to 85 feels the same. But from 85 to 90, there is some heat coming out, but not hot. I would think that if the system is operating normal, the temperature should get a little hotter with each digit going up in increments. The car was definitely warmed up and the AC was OFF. Has anyone ever experienced this before?
My 09 acts the same way, just not all the time
At times I was also thinking there must be something wrong.
Not ruling out that something actually "is" wrong, but, IMO, I think the following post explains it because from my experience I came to the same conclusion .. for what it's worth.
The temp settings aren't supposed to be the temp of the air coming out of the vents. The temp setting is for the desired temp inside the car. The temp inside the car is determined by sensors in the cabin.
Ex.; If it's sunny and 75° and you set the desired temp at 75° the A/C will come on (cool air) until the interior gets to 75°. If it's sunny and 40° outside and you set the desired temp at 75° the heater (warm air) will come out of the vent until the interior temp reaches 75°.
Here in Austin I've had the A/C kick in on a sunny day when the outside temperature is 60 and the desired inside temp set at 78°. Between the heat from the exhaust and the firewall and the heat from the sun the car needs A/C on a 60° day to maintain 78° inside..
I have to agree with your thoughts/reasoning because I've experience the same thing.
The one constant I find is when it's cool/cold out and Not sunny, the system works like I would expect it to from a cold start and just starting out for a drive.
And other times making adjustments after driving around for a while, with the temperature already established in the car as you say :
"Between the heat from the exhaust and the firewall and the heat from the sun the car needs A/C on a 60° day to maintain 78° inside"
it seems all that affects how the system reacts trying to automatically attain the temperature it is set to.
It's doing what it's supposed to, just doesn't seem like it.
For me, unless it's really cold out, I rarely have to set the heat higher than 68.
I'm usually running the AC to keep it from getting too warm, even when it is cool/cold out
Just my thoughts and experience for what it's worth
Old Feb 26, 2012 | 06:31 PM
C8-Vette's Avatar
C8-Vette
Try the simple solutions, disconnect battery for 30 minutes/ hold a number of buttons for whatever. If that don't work you probably have a torn shroud and/or one or more bad actuators. The C6 has no doors. It have a large shroud that moves back and forth propelled by the actuators. The shroud is like a large roll of 35 mm film.
My HVAC (2005) went nuts a few years ago. The shroud and both actuators were replaced. Bad news is that the dash has to come off. Had it done by my local Caddy dealer under ex warranty. Cost w/o warranty $1550. I chose the Caddy dealer over Chevy dealer because they were able to diagnose the problem while my Chevy dealer was just blowing smoke. The Caddy XLR has the same unit and they had some experience , none with the Chevy dealer. When the dash is removed don't go to the dealer to see it, it will make you sick.
I have the old shroud in my garage, it was badly torn .
Good Luck
Old Feb 26, 2012 | 07:11 PM
cleif2000's Avatar
cleif2000
St. Jude Donor '21 thru '26
Great information.
Old Feb 29, 2012 | 01:43 AM
JCtx's Avatar
JCtx
Can you take a pic? Curious to see what it looks like.
Old Feb 29, 2012 | 01:02 PM
C8-Vette's Avatar
C8-Vette
Check your private messages
