tires changing
Old Mar 1, 2012 | 06:20 PM
jjrctech's Avatar
jjrctech
Default tires size
when changing tire how important is it to keep the factory
275-35-18 = 96.25
325-30-19 =97.50
-1.25 ???
what thinking to change to
275-35-18 = 96.25
305-30-19= 91.5
+4.75
Old Mar 1, 2012 | 07:27 PM
JoesC5's Avatar
JoesC5
275-35-18 = 96.25
325-30-19 =97.50
-1.25 ???
275-35-18 = 96.25
305-30-19= 91.5
+4.75
To keep the Nanny's running as designed, you need to keep the front/rear bias. The rear tires need to be in the 1.2" diameter range larger the the fronts. Not smaller as you want to go.
Old Mar 1, 2012 | 07:37 PM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
your abs and traction control will vomit.
Old Mar 1, 2012 | 07:48 PM
jjrctech's Avatar
jjrctech
can it be bigger then 1.2
305-35-19 106.75
Old Mar 1, 2012 | 07:53 PM
Like dem Vettes's Avatar
Like dem Vettes
Why narrower?
Old Mar 1, 2012 | 08:00 PM
C3 Vette Fan's Avatar
C3 Vette Fan
If anyone would know WD would..
Old Mar 1, 2012 | 09:52 PM
JoesC5's Avatar
JoesC5
305-35-19 106.75
What is the 106.75 you post?
The rear tires need to be ~1.2 inches larger in diameter then the front tires.
Old Mar 1, 2012 | 10:06 PM
jjrctech's Avatar
jjrctech
I am change the rims on a basic c6 not z06 I have
275-35-18
325-30-19 which I know are good and 1.2in
But they are to big
I am looking at
275/35-18 Front 96.25
305/30-19 Rear 91.50
4.75
Old Mar 1, 2012 | 10:09 PM
jjrctech's Avatar
jjrctech
what other tire size would work?? other then
285-35-19 99.25
245-40-18 98.00
To tires changing
