iPhone and Bluetooth
I haven't attempted this method with the iPhone 4S (yet), but I see no reason why it shouldn't work just fine, and it's probably what I'm going to have to resort to. To me, it's inconvenient because I have to manually input contacts into the system one at a time. When all the names/numbers I would want to call are already stored on my phone, this seems like a major waste of time. This is where Voice Pass-Thru is supposed to come to the rescue.
According to the owner manual, Voice Pass-Thru is supposed to "allow access to the voice recognition commands on the cell phone". You press the talk button, say "Bluetooth", then say "voice", and the car then activates the voice command functionality on your phone (Siri in the case of the iPhone 4S) which you can then use to dial any contact that's already stored on your phone. This is when I start running into problems with the 4S.
On my old iPhone 4, which had only basic voice commands, this worked flawlessly. I would say "call John Doe", and the phone would place the call. What happens to me more often than not on the iPhone 4S is that I hear the voice/Siri prompt and before I can even start saying a command it cuts me off and disconnects from the phone. It does the same thing when I activate Siri directly by holding down the home button on my iPhone (instead of using the steering wheel button in the car).
Unfortunately, I've found that the only reliable method of placing in-vehicle calls on the 4S is to unlock the phone and actually tap on the name of the contact whom I want to call, which defeats the whole purpose of handsfree calling. Nobody--myself included--should be fumbling around on a touchscreen phone trying to place a call while driving a car.
Never had a problem with my 2012 when I initiated the call while the car was running. I normally initiate the call via bluetooth, though. Rarely from the iPhone itself.
J.R.
Phone will pair easily, but soon as I get started making a hands free call, it disconnects and says, "Thank you."
