Differences in C6s
Old Mar 17, 2012 | 11:00 AM
Voytek's Avatar
Voytek
Default Differences in C6s
Can someone answer a couple questions?
Is the new GS the same body as the zo6? no targa? How does it compare handling wise to the zo6?
What's the difference between 2lz and 3lz?
I know I can probably search this but on the phone it's difficult.
Old Mar 17, 2012 | 01:42 PM
CO Lightfoot's Avatar
CO Lightfoot
...I know I can probably search this but on the phone it's difficult.
maybe later... right now my thumbs are kinda tired.
comparison test @ http://www.roadandtrack.com/tests/car/corvette-fever
Old Mar 17, 2012 | 02:17 PM
mpuzach's Avatar
mpuzach
GS and Z06 have different front fender panels; otherwise body panels are the same.
I haven't driven either so can't comment on handling.
GS coupe has removable roof panel, Z06 does not. (GS is also available as a convertible.)
3LZ adds stitched leather-covered door panels and upper dashboard.
Grand Sport
Z06
Old Mar 17, 2012 | 02:20 PM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
A Z06 posted the 11th all time fastest lap at Nurburgring. It's a race car. Period.
The GS gives you the wide body look w/ good brakes and a removeable top.
99 times out of 100, the GS is enough car for any enthusiast.
Old Mar 17, 2012 | 06:58 PM
haljensen's Avatar
haljensen
Similar body on the GS but no carbon fiber parts, has a steel frame instead of the aluminum frame of the Z06 so the GS is heavier.
Same brakes and tires so the weight difference would affect the handling (as would the GS 430 HP compared to 505 HP in the Z).
Old Mar 17, 2012 | 07:02 PM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
GS suspension is between the Z06 and Z51. Unless you get them on the track I doubt if you'll notice a difference.
Old Mar 17, 2012 | 07:04 PM
OnPoint's Avatar
OnPoint
The Consigliere
And a fella by that goes by the handle of LaconiaJack will try to tell you that even considering a GS is raw stupidity.
OP, visit GM's website, the comparison article CO Lightfoot linked above, and go test drive them.
Old Mar 17, 2012 | 09:15 PM
laconiajack's Avatar
laconiajack
Not at all. If you want the wide bodied look, can't afford the Z06, can't shift a manual transmission, want a removable roof panel, or a convertible, the G/S is a perfectly logical choice.
Old Mar 17, 2012 | 09:25 PM
Speedway1's Avatar
Speedway1
Has NOTHING TO DO with affording a Z06! Depends on what YOU want PERIOD! IF you can afford the GS you can afford the Z06!!
Old Mar 17, 2012 | 09:47 PM
Gary '09 C6's Avatar
Gary '09 C6
maybe to some, but not to all...
the starting MSRP difference between the GS coupe and the Z06 is just under $20K. That's a hefty difference...
Old Mar 17, 2012 | 10:48 PM
djmano's Avatar
djmano
From: Intersection of Eau Rogue, Flugplatz and Loews Hairpin
there's a reason the grand sport sells so well....last time i checked it was about ~30-40% of all corvettes ordered.
i think a Z06 is overkill unless your an avid track enthusiast. even a base C6 can land you in jail in about.....12 seconds?
Old Apr 15, 2012 | 09:28 PM
Speedway1's Avatar
Speedway1
Yes but in the used car market one can get a Z06 for the price of a GS though the Z06 may be a year older or more. My 2010 3k miles GS is about the same money as a 08 Z06 with low miles. Getting a new one is a different story. 20k could be a factor!
Old Apr 15, 2012 | 10:28 PM
Gary '09 C6
I agree---used, the price differential can be closer. Obviously availability of warranties (original and/or extended)
can also be another influencing factor in deciding new vs used.
To Differences in C6s
