2-3 shift issues
Old Mar 19, 2012 | 07:06 PM
6spdg37s's Avatar
6spdg37s
Default 2-3 shift issues
I have an 08 z06
whenever i am hard acceleration 2nd gear and go to shift to 3rd it doesnt let me get into 3rd..
it almost feels like the gate is closed... i then let off and let the revs fall and it lets me shift into 3rd. this kills my time and makes me look like i cant drive.
my question is what RPM do you all shift at to get a great 2-3 shift ?
Old Mar 19, 2012 | 07:13 PM
dvilin's Avatar
dvilin
You should be able to shift from 2nd to 3rd without any difficulty at any RPM. I have found at higer RPM's and attempting to shift fast it is easier if you push the shifter up with the palm of your hand instead of gripping it and shoving into gear. Not sure this helps but it works for me.
Old Mar 19, 2012 | 07:18 PM
michaelinmech's Avatar
michaelinmech
Originally Posted by 6spdg37s
I have an 08 z06
That should not be the case. You have either a mechanical issue or driver error. If you are confident it's not you, get your car into the dealer for service.
trivette's Avatar
trivette
I agree with the suggestion. That was an issue for me as well when the '05 was new. Apparently the spring-loaded(?) assist for changing gears works best when gently guided with your palm and not forced as it would be when gripped as you would normally expect. There have been numerous threads/posts on this subject and the solution has always been the use of your palm.
Old Mar 19, 2012 | 07:19 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
I have an 08 z06
This sounds odd, because the 1-4 shift pattern is supposed to work at lower rpm's to save gas. This would lock out 2 and 3, and force you to go to 4th when traveling at lower speeds. However, whenever I would accelerate keeping the revs up, it would never lock out 2nd or third. In truth, lot of times I just shift from 1st to 3rd. It saves on that extra shift, and the car runs pretty smoothly that way under normal driving conditions.
You can get a cags bypass to eliminate this in your car. It fits into the wiring harness, and stops this shift lockout.
Also, I had Chuck at Corvettes of Westchester tune my car. His tuning eliminates the need for the cags insert, and stops this problem. It also improves other aspects of the cars performance.
Old Mar 19, 2012 | 07:22 PM
06 Blown's Avatar
06 Blown
i suffered the same whenever i had some " Spirited" driving and tried a little too aggressively to shift from 2 to 3, try the palm trick it worked for me.....
Old Mar 19, 2012 | 07:30 PM
WICKEDFRC's Avatar
WICKEDFRC
Sounds like a 2-3 issue I had as well on my C5..... This was following a new clutch install whereas prior to, my shifts was insane smooth. I never did find the true issue (perhaps a faulty slave cylinder?), but I installed a Tick Master Cylinder and the high RPM shifts went away. I am not saying this is what you need, but it sounds the same as my issues.
When you do your shifts, make note of the RPMs that it effects, such as 6500, 6000, 5500, etc.
My shift issues from 2-3 went away anything UNDER 5000 rpms. After I installed the TICK and tuned the fluid flow, I had no more issues.
Another thing to test is, check to see if your clutch is fully disengaging.
A simple test:
Find very wide open parking lot.
Let car idle facing large open spot in parking lot (no obstructions or obstacles)
Press in clutch pedal fully to floor and continue to hold in.... While holding pedal to floor, bring RPMs up to 6500 for 10 seconds. Does car move? if NO, try test #2.....
Second test is same as first, but this time, press the clutch pedal in and hold it in for 30 seconds THEN rev up the car to 6500 RPMs. Does car begin to move?
My car did NOT move on the first test, but sure as hell moved when I held the clutch in for 30 seconds, then brought RPMs up to 6500. So, when I installed teh TICK and adjusted the pressure of the fluid, my car no longer moved when the clutch pedal was pressed in (symbolizing the pressure plate was not fully disengaging) and, my shift issues went away.
I am not sure if this would be the same for a C6, but its an easy test, and its free to try.
Old Mar 19, 2012 | 07:53 PM
v26278's Avatar
v26278
+1 for the "palm" technique. Works for me.
Problem is, at WOT the adrenalin is flowing and you can push the shifter too hard sideways if you "grab it" and miss the shift. If you let the spring in the shifter do the work to go from the 1-2 "slot" sideways over to the "3-4" slot, it will get it right and you'll slide nicely into third, use your hand to only provide forward motion. Kinda freaky cause you think you might go down to 1st instead of up to 3rd, but hat is what the spring is designed to prevent ( I think). Practice it and its easy to do fast at any RPM
Also look into an MGW shifter, it's shorter throw and stronger spring help a lot.
Old Mar 19, 2012 | 08:09 PM
BlueOx's Avatar
BlueOx
Totally agree with the 'heel' of the palm 2-3 shift. Too many folks try too hard to 'steer' the shift. Just push it forward with the heel of your palm and it will move through the shift just fine as you push it forward. Works very quick and fast for me.
Practice it and see for yourself.
Old Mar 19, 2012 | 09:19 PM
jpgolf14's Avatar
jpgolf14
i ran into the problem as you describe. i used to own a 69 4-4-2 and never had the problem flat shifting that hurst shifter, so pretty sure it is not me. switched to a MGW shifter and the problem went away. you may want to consider that (it worked for me)
Old Mar 19, 2012 | 11:15 PM
6spdg37s's Avatar
6spdg37s
thanks for the responses guys...
I just tryed again before not on the track and no problem
so my feeling is at the track adrenaline and revs are flowing... and it is driver error...
so probably what is happening is i am hitting the gate slightly sideways or something of that sorts...
i did have the car checked out with the 3rd gear cold syncro TSB but no fix or real problem with it
I wanna do the MGW eventually...
for now I will try to watch how i shift which technique i use
To 2-3 shift issues
