Oil pressure question
What should my oil pressure run in my low miles 2011 g.s ? At idle its around 50, and on acceleration it goes into the 70's. Oil temp on short runs to the gym (2 miles) is in the 130's, ambient temp is in 70's. This just seemed high when i noticed it today. If this is too high, what could be the problem ? Thx, i appreciate your feedback.
Mine runs 80 psi cold at idle. I try not to rev it up until it warms up. Oil temp stay 50 degrees lower than water temp. GS dry sump.
Yours seems just fine.
Rule of thumb on all engines. You need 10 psi for every 1000 RPM. That is a warm engine, ready to run hard.
Cold at idle mine is about 50 psi and goes to about 65-70 with a few revs. Warm at idle its about 40 psi and goes up to 55 or so with a few rev. These oil pressure sensors vary. On my C5 the warm idle pressure was under 30. After changing the sensor it was about just under 40.
Don't worry about. If you hear your engine start to clank or make clattering sounds then worry.
