Is it true?
Unbranded and branded gasolines come from the same tank. The additive package is just different.
In the Cincinnati market some terminals are fed by barge, some by pipeline. The amount of crap that goes into the storage tanks is alarming. The best thing to do is always avoid a store that is getting a delivery. Of course you would never know if a truck just left
All gas shipped via pipeline is the same. Once at a terminal, additive packages that make Chevron, Chevron gas, are added as the transport is loaded. This includes the ethanol component Unless the store in question has Chevron brand signage, it is likely an unbranded sale which may or may not contain the complete additive package.
So they could be right about Safeway. Research their website or google Chevron Safeway and see what comes up.
As pointed out by others in the thread, unbranded gas like Safeway or Wal-Mart or whatever sometimes comes from the big oil companies like Chevron. Sometimes that is done on a long term contract basis, but more often, they just use whoever is cheaper at the moment. Also sometimes, depending on the delivery route, you may even get the branded additive at a cheapo station. It’s perfectly legal to give you more than you pay for. Trouble is, you can’t rely on it being there. More often, even if there is a contract between, for example, Safeway and Chevron, to supply gas, the gas that gets supplied would be Chevron’s base gas, but with generic additive package rather than Chevron’s top tier package.
And finally, the base gas. Just because “it all comes from the same pipe” does not necessarily mean it’s the same base gas. You can segregate shipments in the same pipe. This is proven by the fact that the same pipelines carry varying octanes of gasoline, as well as diesel and jet fuel all the time. If the contracts are written to keep things separate, they will be separate, even if from the same terminal delivered by the same pipeline. The segregation will be done via different batches in the pipeline to different tanks in the terminal.
Of the three issues above, top tier is most important, the fact that cheapo gas is sometimes, but not very often the same including additives as the top tier brands is next most important, and the “all from the same pipe” issue is least important. What importance the “all from the same pipe” issue has is mostly because if you start believing too strongly in the “all from the same pipe” thing, you will ignore the other two issues. It isn’t all the same, gang. Choose to believe the internet engineers if you wish, but I’m a real engineer with 40 years of real refining experience, and can guarantee you that top tier users will have cleaner engines than non-top-tier users.
In doing some reading about Top Tier gasolines, I have come to understand that a Top Tier label qualifier is that the Top Tier designation requires (simplified explanation for dicussion) that the fuel must produce at least twice the federal minimum effectiveness of cleaning in test engines. The question I have is that the Shell brand advertises that its premium fuel, Shell V Power has Five (5) times the detergency level of the federal minimum standard. Assuming that this is true, does that translate into five times the cleaning level in my engine?
I have not seen any other fuel brands making any specific claims other than being Top Tier rated. Do you know if the Shell claims result in actual significant improvement (reduction) in combustion chamber, piston, and valve deposits over other Top Tier advertised brands?
Barry
76 Stations
Aloha Petroleum
Chevron
Conoco
CountryMark
Entec Stations
Exxon
Hawaii Petroleum
Holiday Stationstores, Inc.
Kwik Trip / Kwik Star
MFA Oil Co.
Mileage Stations
Mobil
Phillips 66
Quik Trip
Rebel Oil
Road Ranger
Severson Oil
Shell
Texaco
Tri-Par Oil Co.
U.S. Oil
I've used Murphy (Wal-Mart) premium 93 for the past several years with no adverse effects. They're easy to find on trips too.
