Chirping Sound
Old Mar 25, 2012 | 06:19 PM
nevillej's Avatar
nevillej
Default Chirping Sound
When driving the backroads the other day going between 40-50 MPH with the radio off as I went over some dips/bumps in the road I would hear a chirping sound from what seemed to be the front suspension. The car has only been out 3-4 times this season, are there any areas of the chassis that may require lubrication or is it the sign of something with the suspension.
I would think that with only 27K on the car the suspension would be O.K., any ideas??
Old Mar 25, 2012 | 08:40 PM
littlefranks's Avatar
littlefranks
retorque the 4 cradle bolts.was the front bushings on leaf spring cut to lower car .could be bottom of bushings on leaf spring meeting lower control arm.
Old Mar 25, 2012 | 09:39 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
The chirping sound I had was my harmonic balancer, I never heard a suspension chirping. It doesn't chirp ever at idle?
Old Mar 25, 2012 | 10:29 PM
nevillej's Avatar
nevillej
No noise at idle, rare at highway speeds (but the roads are a bit better), but on backroad twisties which I luv, normal shaking of chassis with some rattles but the obnoxious chirp will drive me nuts (unless I obviously crank up the radio). As I drive the car more, now that the season is here in New England I will drive more without the radio to see if it gets worse or eventually goes away. If I went to a dealer with this they would probably thing I'm nuts or not be able to isolate the problem. I'll write down everyone's suggestions to pass along when/if I go to a dealer.
Thanks All - Jeff
Old Apr 4, 2012 | 11:07 AM
corvette-kyle's Avatar
corvette-kyle
I have this same chirping noise but it seems to be coming from the back - most noticeable at lower speeds over bumps as there's less road noise. Would like to see if anyone else knows what this might be...
Old Apr 4, 2012 | 12:33 PM
el es tu's Avatar
el es tu
worn out suspension parts or unlubed suspension parts will definitely do this.
try lubricating one thing at a time and testing until you narrow it down.
Old Apr 4, 2012 | 01:58 PM
JoesC5's Avatar
JoesC5
There are no lubrication points on a C6 except for the rear toe links(Zerk fittings) on the Z51/Z06/ZR1/GS cars.
Old Apr 4, 2012 | 02:09 PM
el es tu's Avatar
el es tu
I think Ive been looking at too many aftermarket parts - the stock stuff really doesnt have much provision for lubrication
stuff that can be lubricated:
endlinks - aftermarket is obvious, but you can use a siringe to inject grease into the stock ones
sway bar bushings
and like you mentioned the tie rod ends
worn out control arm bushings can sometimes be lubricated to temporarily make the sound go away in order to isolate the issue
To Chirping Sound
