Harmonic balancer replacement
Old Mar 26, 2012 | 01:45 PM
NARIMAN's Avatar
NARIMAN
Default Harmonic balancer replacement
I had some squeak from under the hood, sounded like belt needs to be replaced
Took it to the dealer and they told me that harmonic balancer bushing is gone and needs to be replaced
Is it common?
What could cause that?
Is there any aftermarket better part avail?
Old Mar 26, 2012 | 01:48 PM
OnPoint's Avatar
OnPoint
The Consigliere
Is it common?
Wouldn't call it "common", but several have had the same issue. Caused by a bad part.
ATI makes an excellent, better than stock, part. However, some dealers will insist on stock GM to keep warranty intact. Your call. If it were me, I'd put the ATI unit on.
Old Mar 26, 2012 | 01:49 PM
EVRose's Avatar
EVRose
HERE is one of MANY threads on the topic.
Old Mar 26, 2012 | 01:54 PM
cclive's Avatar
cclive
If it's on warranty then they will put the OEM part on. If not, then take it somewhere else and have them put on a good aftermarket one.
Old Mar 26, 2012 | 02:43 PM
brooklync5's Avatar
brooklync5
Its probably the MOST common corvette issue that had been discussed over and over again.... I just replaced mine with only 21k miles on the car. The dealer warrantied the part and the labor egen though im years out of warranty. Make enough of a stink about it print out as many pages as yoy can fi d on the issue and bring it to the dealer. If you push hard enough you will get them to warranty it even if yku are out of warranty.
Old Mar 26, 2012 | 03:56 PM
Stickman07's Avatar
Stickman07
Had ours replaced a couple months ago under extended warranty, the back again a couple weeks later to have it all done over again as the replacement was crap too...... Still about $400 out of pocket
Old Mar 26, 2012 | 06:41 PM
bearphoto's Avatar
bearphoto
SoCal Events Coordinator
St. Jude Donor '12
it is fairly common and started with the c5's. if under warranty just take it in.
Old Mar 26, 2012 | 06:48 PM
Goatdad's Avatar
Goatdad
St. Jude Donor '11-'12-'13
It is common, lots of threads.
Just search "harmonic balancer" and way more info than I can type will pop up.
If you can avoid a stock replacement than do so. ATI makes the best but for half the price SLP make a great replacement. Good luck
Old Mar 26, 2012 | 11:38 PM
NARIMAN's Avatar
NARIMAN
thanks
also behind rear wheel was clicking sound during acceleration or decel, and they say some kinda bushing need to be replaced, not sure what
To Harmonic balancer replacement
