I need some help.
Old Apr 15, 2012 | 11:34 AM
JoesC5's Avatar
JoesC5
Originally Posted by CC_Corvette
Seems like the previous owner just put the exhaust on it. I like the sound, I just don't want to lose low end back pressure or toque if any?
So with the NPP exhaust, I now have 436hp and 428tq?
With a functional NPP(and dual mode Z06/ZR1 exhaust) you likely have a little more torque in the lower RPMs with the valves in the closed position, but a little more torque and horsepower at higher RPMs due to the valves opening at ~3500 RPM.
Running the valves open at lower RPMs might be hurting your low end torque(but I doubt if you can feel it, just as I doubt you can feel the additional 6 HP increase when the valves are open at higer RPMs).
There is an aftermarket kit that allows you to have a fulling functioning NPP exhaust.
Old Apr 15, 2012 | 11:45 AM
z51vett's Avatar
z51vett
Buy an after market controller for npp and install you are almost home they can be had for around 2 something and the mufflers are around 1500.
z51vett
Old Apr 15, 2012 | 11:48 AM
CC_Corvette's Avatar
CC_Corvette
Originally Posted by MikeyTX
If you leave the valves in the open position .......... The engine has always produced those numbers. The base, non NPP axle back muffler system, chokes things down. That's why the Corvette w/ NPP can advertise higher numbers. Simply said, when the valves open, the system is more free flowing, thus the higher hp/torque rating. You'd need a dynamometer to really see the difference. What you need to do is buy the M2W accuator kit from one of the forum vendors that will make the NPP functional.
Any recommendation? I see so many of them... How hard is it to do it yourself? I have no LIFT.
Old Apr 15, 2012 | 11:57 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Where in TX are you ? There are many great shops in TX that can do the install for you.
Old Apr 15, 2012 | 12:36 PM
CC_Corvette
DFW are. The NPP Exhausts are already installed when I got the car.. the previous owner just didn't bother to hook the hose up or anything.. so it stays open all the time.
Old Apr 15, 2012 | 05:02 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
This is gonna be easy then. Get hold of Anthony or Bobby at LG Motorsports or, Matt at 21st Century and explain what you want to do. Either shop can do the job and get the vacuum assy you need to make the NPP functional.
Old Apr 15, 2012 | 05:18 PM
CO Lightfoot's Avatar
CO Lightfoot
From Southern Car Parts:
http://www.southerncarparts.com/corv...ox-p-2724.html
Old Apr 15, 2012 | 05:37 PM
JoesC5's Avatar
JoesC5
Or, if you want to save money, buy a hand vacuum pump at harbor frieght and some vacuum hose. Drill a small hole in the floor of your rear hatch, run the tubing under the carpet up to the front, and hook up the hand operated vacuum pump. When you want to close the exhaust valves, give the hand pump a couple of squeezes and when you want them open, release the vacuum.
Old Apr 15, 2012 | 06:27 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
I was going to follow up your post with one about my ex wife but I figured ..................
Old Apr 15, 2012 | 06:29 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Originally Posted by CO Lightfoot
Uh huh ............ that's the kit I was thinking of. He can get it from both of the local forum vendors I suggested he call for the install.
Old Apr 15, 2012 | 06:59 PM
CC_Corvette
Does this kit allows the automatic functions of the NPP? Close at low RPM and when I open her up to 3500rpm, it opens and close when I let off?
Old Apr 15, 2012 | 07:02 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
That kit lets you open or close at will. Your car doesn't have the computer module that controls the factory NPP.
Old Apr 15, 2012 | 08:20 PM
  #33
JoesC5's Avatar
JoesC5
I was originally going to offer that as another source of a vacuum, but decided to stick strictly with the hand pump. Some things are better left up to the imagination and not spelled out.
Old Apr 15, 2012 | 09:51 PM
  #34
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Yup, my thoughts exactly.
Old Apr 16, 2012 | 02:52 AM
  #35
AtHomeSoda's Avatar
AtHomeSoda
Default ah..
Yo dude.. you Can open and close the butterflies ANYtime you WANT... Get the NPP In Box... You got a great deal,,, enjoy it...
Old Apr 16, 2012 | 05:16 AM
  #36
CO Lightfoot
From another thread:
Originally Posted by Top Flight Reproductions
npp in a box only gives you open or close function, no rpm open functions.
http://forums.corvetteforum.com/c6-t...-in-a-box.html
By Michael S. Palmer | 2026-06-03 11:00:24
