Can't Shift 05 Automatic
Old Mar 30, 2012 | 12:41 PM
TCKT B8's Avatar
TCKT B8
St. Jude Donor '09 & '11
Default Can't Shift 05 Automatic
I can't shift my 05 automatic sometimes after I stop and put it in park. If I
turn it off and restart it will shift. I'm thinking maybe reboot the computer. Would disconnecting the battery work?
Old Mar 30, 2012 | 01:20 PM
EVRose's Avatar
EVRose
That happens a lot and when it gets to the point that it won't come out of park at all the only fix is to replace the shifter.
Old Mar 30, 2012 | 01:30 PM
Goatdad's Avatar
Goatdad
St. Jude Donor '11-'12-'13
Hey neighbor,
I just fixed my a6 shifter but I had a different problem than you have. The shifter for the a6 is about $229, I'm sure the a4 is similar and hopefully no more money.
I can swap one out in about an hr. If need be. I'd be glad to help if you need it!
Old Mar 30, 2012 | 01:37 PM
AD2VET's Avatar
AD2VET
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
Same thing happened to my A4. After I finally got it out, to me taking the console off is a major PITA, I just decided to cut the locking tab that the solenoid controls. Now the shifter works just like the one in my C3 (i.e. no lockout at all). This way the solenoid is still there and the computer thinks everything is the same as before.
TCKT B8's Avatar
TCKT B8
I've only put 19,500 mile on the car. Does this mean we have to replace the shifter every 20k miles or so?
Old Mar 30, 2012 | 03:13 PM
degaux's Avatar
degaux
Had this happen to me.... $700 later all is ok
Old Mar 30, 2012 | 03:42 PM
Goatdad's Avatar
Goatdad
Its common but not that common.
Old Mar 30, 2012 | 03:46 PM
redrckt97's Avatar
redrckt97
I've got 50k on my 05 and its only "stuck in park" a couple of times--
I had read on the forum to put the car in accessory mode (motor off) and then move the shifter to neutral and hit start -- worked perfectly for me. I guess eventually the shifter has to be replaced though??
Old Mar 30, 2012 | 03:47 PM
Goatdad's Avatar
Goatdad
Ya, I don't get how they can charge so much. With no experience one can remove the console properly in 30min or less and swap the shifter in 5min and then put it back together in 30min.
For me the hardest part was the ****! Now I can remove a **** in less than a minute with no tools.
To Can't Shift 05 Automatic
