Defrost Button Issue
Old Apr 5, 2012 | 01:12 PM
VetteTico's Avatar
VetteTico
Default Defrost Button Issue
I have a 2005 coupe. So in the owner's manual it says to defrost the windshield/rear you press the two buttons on the dash (red arrows); however, I can't press those two buttons - they are hard as a rock. Am I missing something?
Old Apr 5, 2012 | 01:36 PM
Eritosthenes's Avatar
Eritosthenes
Sounds like something has gotten in behind the buttons, or into the switches themselves and gummed them up. Maybe a shot of canned air around the edges will blow something out from behind?
Old Apr 5, 2012 | 01:47 PM
EVRose's Avatar
EVRose
Some of my buttons get like that too. Press HARD and they will unstick and work. I shot some electronic parts cleaner all around the buttons and it freed them up.
Old Apr 5, 2012 | 01:59 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
The 2 buttons right in front of the cup holder that could be the source of genuine RC Cola splashing on the buttons, seeping behind them and locking the buttons in place? Those 2 buttons? Electronic parts cleaner might free them up. They are supposed to move when you push them.
Elmer
Old Apr 5, 2012 | 02:00 PM
VetteTico's Avatar
VetteTico
Thanks guys. I'll try that tonight - I didn't want to break anything.
Old Apr 5, 2012 | 02:01 PM
VetteTico's Avatar
VetteTico
Thanks, you're probably right!
Elmer
Old Apr 5, 2012 | 02:04 PM
cclive's Avatar
cclive
I think Elmer has it...they are suspiciously right in front of the cupholder....
Old Apr 5, 2012 | 02:07 PM
EVRose's Avatar
EVRose
It's not just those that get stuck. At one time ALL of mine were sticking. Even the heated seat buttons.
Old Apr 5, 2012 | 02:27 PM
funymuny's Avatar
funymuny
WD-40...one of my must-have cure-alls.
Old Apr 5, 2012 | 03:06 PM
Daekwan06's Avatar
Daekwan06
My defroster button sticks too. Will try some WD40, if I can remember next winter.
Old Apr 5, 2012 | 08:49 PM
VetteTico's Avatar
VetteTico
Thanks guys. WD-40 did the trick
Old Apr 7, 2012 | 10:54 AM
MACowley's Avatar
MACowley
Good to know, mine was doing the same thing after I bought it...only mine was the A/C button. Took it in to the dealer (still under warranty), and they replaced the entire unit.
Old Apr 8, 2012 | 07:51 AM
funymuny's Avatar
funymuny
Anything to keep a car away from the dealer. Glad WD40 did the trick. It's pretty good at breaking down that kind of thing, and lubricating as well.
Interesting story about the origins of WD40, and what it was intended to do. If you ever get bored look it up. And learn what the WD stands for. Might be a trivia question sometime...Mark
Old Apr 8, 2012 | 08:16 AM
JKbride's Avatar
JKbride
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
I know it's after the fact for some, but I would not use WD 40 to unstick the buttons. Using a thin oil or other liquid to un stick an power button and your asking for an electrical short, which with either blow a fuse or short out the switch.
In the future I would use compressed air to make sure it's not blocked and if still stuck (ala RC Cola) then wait for a warm day ( or use a hair dryer on a low setting) and try to free them up by pushing a little harder .
Old Apr 8, 2012 | 08:31 AM
rc135_tx's Avatar
rc135_tx
Originally Posted by JKbride
I know it's after the fact for some, but I would not use WD 40 to unstick the buttons. Using a thin oil or other liquid to un stick an power button and your asking for an electrical short, which with either blow a fuse or short out the switch. ...
Go here http://www.wd40.com/search/, enter "electrical" in the search box. WD-40 is non-conductive.
If it doesn't move & should: WD-40.
If it moves & shouldn't: Duct Tape.
Old Apr 8, 2012 | 08:39 AM
JKbride's Avatar
JKbride
Heck that's awesome!
That stuff is used so many ways I wonder how it would work as a oil vinegrette salad dressing
(note to self, while at Lowes today buy more WD-40).
Old Apr 8, 2012 | 10:07 AM
funymuny's Avatar
funymuny
Yep, many many uses. While I believe it is non-conducive for electrical purposes, I did not mean to suggest soaking the part in WD40. The surface tension, it seems, would cause the WD40 to want to run along the edges of the plastic molding and gravity would pull it downward.
In my head (did not type it) I was envisioning a few light sprays/drops at the top of the starter switch that would allow the WD40 to roll down the sides. The wires/connectors are fairly well concealed behind the switch. Besides, whatever was causing the sticking (RC Cola, whatever) would unlikely get anywhere that the WD40 could not get.
Because of this thread later today I am going to get my ohmmeter and test the conductive properties of WD40.
To Defrost Button Issue
Old Apr 8, 2012 | 01:42 PM
funymuny's Avatar
funymuny
I did my test...clearly not a controlled environment but good enough. Stuck my ohmmeter leads in water...the needle moved a little showing some conductivity. I sprayed WD40 in a small cap and did the same. No meter deflection.
Now, start cranking 20000 volts and high amperage maybe a different story.
That's all from me...
Old Apr 8, 2012 | 09:10 PM
cclive's Avatar
cclive
I have used WD-40 to dry the inside of a distributor cap that has gotten condensation in it. It is great for electrical contacts because the film it leaves prevents corrosion. "Water Displacement 40"
Old Apr 8, 2012 | 09:51 PM
Zoxxo's Avatar
Zoxxo
Dating myself... back in the early days of sponsored, competitive slot racing in SoCal (mid 1960s) our electric motors were being built by TRW and we used to spray WD40 directly onto the motor's rotating commutator for both lubrication and cleaning. Never once stopped or hurt a very expensive motor.
Z//
