Do you believe it?
Old Apr 16, 2012 | 09:44 AM
Toilets's Avatar
Toilets
Default Do you believe it?
Does anyone have a subscription to GM high-tech performance?
In their latest edition, they tested a new 2012 GS centennial edition and it made 415rwhp and 409rwtq. They didn't believe it themselves so they did 3 pulls and all within 1 hp of each other. Very impressive!
Anyone who knows about this magazine knows they are very reputable.
They even go on stating the ls3 dry sump should be re-certified haha.
Anyways, given the average 12% drive train loss, you are looking at around 470hp to the crank.
So, what are your thoughts?
I looked on the Internet and I can't attach a link.
Old Apr 16, 2012 | 09:46 AM
boraxman's Avatar
boraxman
Old Apr 16, 2012 | 09:58 AM
Toilets's Avatar
Toilets
The dyno used btw was a dyno jet chassis dyno
Old Apr 16, 2012 | 10:01 AM
not08crmanymore's Avatar
not08crmanymore
Good numbers for sure.I'm sure that if they were using 3 different dyno's instead of one that would give them 3 different numbers though.So who knows if their number are completely accurate.
TLS_Addict's Avatar
TLS_Addict
My thought is you cant compare a dyno of one car from one place to another car from a nother place. Also, you can make a dyno read what you want it to. Not calling B.S. on the numbers but they seem extremely high. Also, I would put the manual cars closer to 15% and the automatics closer to 18-20% drive-line loss.
Numbers can be manipulated very easily and a dyno should only be used to track your gains from modifications.
Old Apr 16, 2012 | 10:04 AM
Toilets's Avatar
Toilets
Same dyno just 3 different runs. And was done on a cold day in Tampa
Old Apr 16, 2012 | 10:11 AM
Larry/car's Avatar
Larry/car
Cold dry day and a high pressure weather system. It would be interesting what dyno numbers come up on a standard day (15C/58F, 1013.2 MB/29.92 inches). I would assume that rated HP is computed with standard day numbers.
Old Apr 16, 2012 | 10:31 AM
TLS_Addict's Avatar
TLS_Addict
Thats all well and good but that car on another dyno wont make those same numbers, you get that, right? Each dyno is different and weather is a huge determining factor. Plus, they can "play" with the dyno to have it read whatever they want.
Old Apr 16, 2012 | 10:35 AM
Toilets's Avatar
Toilets
Yeah I understand. Don't kill the messenger, lol. I was rather taken back in the numbers and have a bit of interest in this since I actually own this car. I guess the real test will be to take it to my buddies shop with a dynojet and see what I can actually get.
Old Apr 16, 2012 | 10:47 AM
TLS_Addict's Avatar
TLS_Addict
Not killing the messenger.
The fact is a lot of cars are rated low from the factory.....case in point the Challenger SRT8 with the 6.4 Those things are rated at 470/470 but are putting 430/420 hp/tq from the factory. One reason I didnt buy one is they havent cracked the tune on them yet.
Anyway.....I am not doubting that is what their dyno was showing but I do doubt the actual numbers. I think the highest I have seen anywhere on the net for an LS3 is mid 390s, 20 give or take HP is A LOT considering some LS3s are in the 370-ish range.
Old Apr 16, 2012 | 10:55 AM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
Go run it on a track. That will confirm how much it's putting to the ground. Should be around 118-120 trap @ 415rw.
Old Apr 16, 2012 | 11:22 AM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
Old Apr 16, 2012 | 11:23 AM
TLS_Addict's Avatar
TLS_Addict
What would you know? Hippy.
Old Apr 16, 2012 | 11:26 AM
sledmaster's Avatar
sledmaster
May be they slipped in the LS Hot Cam at the factory. 480hp. and 475ftlb.Tq. in a stock Ls3.
Old Apr 16, 2012 | 11:50 AM
brooklync5's Avatar
brooklync5
Ls hot cam??? Wonder what that does for drivability of our cars??
Old Apr 16, 2012 | 12:51 PM
sledmaster's Avatar
sledmaster
Last year GM performace offered a crate engine model 376/480. This is a stock LS3 motor with the LS Hot Cam. This year they offer one called 376/525. This model has the ASA cam and different valve springs. Looking at the dyno charts it looks like the LS hot cam makes it peaks about 100rpm sooner than the stock cam. The good thing about this cam is you do not have to change valve springs just swap the cam.
Old Apr 16, 2012 | 01:00 PM
TLS_Addict's Avatar
TLS_Addict
GM do the tune for you I take it and no warranty void?
To Do you believe it?
Old Apr 16, 2012 | 01:01 PM
C7&7's Avatar
C7&7
I was shocked when I read that article also.
Old Apr 16, 2012 | 01:03 PM
TNTC4VETTE's Avatar
TNTC4VETTE
Old Apr 16, 2012 | 01:06 PM
TLS_Addict's Avatar
TLS_Addict
It needs more power to motivate its bigger booty. lol
I kid I kid. They have one at the local dealership and I almost wrecked I stared at it for so long the other day.
