Remove the outer tail light (one Torx bolt at the top), reach in and squeeze the plastic clips (same as the fronts), and pop them out.
FYI- When you have the tail light out, you can accidentally knock off the Tinnerman nut that the Torx bolt was threaded into, and lose it.
I know there's two clips on each marker right? Do you squeeze one and push out is that enough ? I remember doing mine and I got really frustrated to the point where one clip broke on both sides. Not sure what the hell I was doing wrong but I'm about to do it again next week with clear markers .
