Jack Stand Question
Jack Stand Question
I am about to start a two day project on my 07 coupe and have a question. Hope it does not sound stupid.
I plan on having the front of the car up on jack stands for about two days. Any issues that I should be worried about with the front up and the rear wheels on the floor in the garage?? Checking all possibilities before I get started tomorrow. Thanks for any input that might come in.
RJ
Western Burbs of Chicago
RJ
Moderator
Received 3,598 Likes
Hey there neighbor Im in the north suburbs. As you're bringing the car up and down the tires will skid a bit as they move from a neutral camber on the ground to a positive camber in the air.
Opposite happens on the way down and corrects in the first 10ft of driving.
If your removing wheels remember to break the lug nuts loose on the ground (wheels will spin once in the air)
Good luck, what are you working on?
If the front subframe (where the jackstands touch) is flat, it's better to have the car level on the air so both sides of the subframe are supported by the jackstand (does that make sense?). But at least on the rear, it's at a steep angle, that even with the rear raised, only the rear portion of the subframe was resting on my jackstands (on preferred locations). If front is the same, just lift the front. But if the front subframe is level, I'd put the rear on ramps to have the car level. And you can basically do any work with the car level (tranny/diff fluid cahnges require car level). Good luck.
By the way SinisterC6, typically only strut-type suspensions turn to positive camber when lifted. I have only lifted my '12 GS on the rear, and both tires were on the air with their same negative camber like if sitting on the ground. That's when I noticed how aggressive the negative camber is. It's probably going to eat the tires on the insides first, but will wait and see.
Jack Stand Question
The installation of my E-Force Supercharger starts tonight. Have done some of the early work and am waiting for my two mechanics to show up at the house to get going. Should be fun getting it done and getting it on the road and track. What suburb are you in?? I am out in Batavia.
RJ
Hello Sinister C6!! Thanks to you and the others that responded to my question. To answer yours, what am I working on??
RJ
RJ
