Spare Tire Issue
Old Apr 18, 2012 | 09:38 PM
Stein's Avatar
Stein
From: Yopper of 52'yrs presently reside in WI Wisconsin
Default Spare Tire Issue
Thinking of purchasing a C6, what suggestions are out there for owners who change out the Goodyear Run flats for other tires that are not run flats and the C6's do not have spares. Not that it would do much good because of the different tire sizes for front and rear. What help can anyone provide?
Old Apr 18, 2012 | 09:43 PM
Vette_DD's Avatar
Vette_DD
Fix-A-Flat and a tire pump.
But I think some here have carried a regular portable tire repair kit.
Old Apr 18, 2012 | 09:49 PM
lt1george's Avatar
lt1george
Carry a GM Pontiac ( AUSTRALIA ) GTO Stowaway spare.
Old Apr 18, 2012 | 09:51 PM
petes ZO6's Avatar
petes ZO6
Spare tire or a 24 hour flatbed tow company on speed dial.
Old Apr 18, 2012 | 10:07 PM
mksz51's Avatar
mksz51
Frequent prayer wouldn't hurt.......
Old Apr 18, 2012 | 10:10 PM
johnodrake's Avatar
johnodrake
Moderator
When it is time for new tires for the CTS, I will install run flats.
Old Apr 18, 2012 | 10:50 PM
TJay74's Avatar
TJay74
UNless the C6 has changed bolt patterns the GTO spare is not the right size. GTO is 5x120, I think the C6 is 5 x 4 3/4 (5x120.65) so that would not be the correct spare I would recommend.
Also seeing as how the C6 has a limited slip rear diff you need to make sure the spare matches the tire height of the rear tires just in case you need the spare on the rear so you dont kill the limited slip diff.
Old Apr 18, 2012 | 11:04 PM
gee350z1's Avatar
gee350z1
Tire plugs and a portable pump thats all you'll really need
Old Apr 18, 2012 | 11:09 PM
jon6.0's Avatar
jon6.0
5x120 vs 5x120.65 isn't going to matter for a spare tire. Manufacturer tolerance make those sizes effectively the same. The GTO spare hub bore size needs to be opened up a little to fit over the Corvette hub. A GTO is 69.5mm hub size. Not sure what a Corvette is, but it's slightly bigger. You can do it yourself with a dremel and a round sander bit. Or take it to a wheel shop to have opened up. If you do carry an actual spare, don't forget a jack to get her up in the air and a lug wrench. Personally I make do with AAA for my daily commuting. For a road trip in the middle of nowhere I would get a plug kit, fix a flat, and a small compressor. You can fit that in the little storage areas in the hatch area.
Old Apr 19, 2012 | 12:36 AM
JCtx's Avatar
JCtx
I'd add a jack kit, especially if you plan to switch to non-RFTs, like I do. I have a very nice jack kit from my M3, but will have to buy one of the rectangular pucks to make it safe (have 4 of the round ones 'permanently' installed). The 'fix-a-flat' is crap, and ruins the TPMS sensor. Best advice is to watch where you drive, but even doing that, got a flat with only 200 miles on the clock. You never know.
Old Apr 19, 2012 | 08:56 AM
JoesC5's Avatar
JoesC5
There is a company that offers a spare tire for the C6(base and Z06). They use a narrowed C6 wheel and a 6" wide tire that is close in diameter to the rear tires. You can run a tire that is larger then the front tires on the front for the purpose of getting you somewhere to get your flat repaired. Not cheap and it does take up room in the rear hatch area. It comes with a mount so the tire is not loose in the rear.
http://vettespare.com/
Old Apr 19, 2012 | 09:07 AM
EDinPA's Avatar
EDinPA
Not really. If you are at any normal highway speed, the tire will be too damaged and off of the rim for that to do any good. Perhaps if you find the flat while parked in a lot before driving on it.
Old Apr 19, 2012 | 09:11 AM
TJay74's Avatar
TJay74
I will say if you buy any of the michelien tires they will actually pay for a tow up to 150 miles to the nearest Michelien dealer under the "Promise" plan they include with their tires.
Old Apr 19, 2012 | 09:20 AM
Top_Fuel's Avatar
Top_Fuel
Some GM cars don't have runflats or a spare tire. This is what is in the trunk of my Pontiac...
Old Apr 19, 2012 | 09:23 AM
designerRob's Avatar
designerRob
Tire plug kit and portable air compressor. Oh, and AAA roadside assistance.
I run Nitto Invo's, more grip and quieter.
I haven't needed either, yet.
Old Apr 19, 2012 | 09:47 AM
car2fast4you's Avatar
car2fast4you
I just switched over to non-run-flats a few weeks ago.
I bought a Slime tire repair kit with compressor.
http://www.slime.com/shop/safety-spair-70005/
I also bought a tire plug kit, plus a small LED flashlight, and a couple of tools.
All of this fits in one of the storage bins in back of the car.
I'm was a little nervous about it at first, but now it's no big deal.
Old Apr 19, 2012 | 11:38 AM
MTsVette's Avatar
MTsVette
From: O'Fallon Illinois - Currently own a 2016 Z06 1LZ A8 Coupe
Pretty much same here (non AAA member). I added a scissor jack to the mix. I'm running BFG g-Force non-run flats with no issues...yet... lol
Good luck...
MT
To Spare Tire Issue
Old Apr 19, 2012 | 11:55 AM
petes ZO6's Avatar
petes ZO6
Some people like to gamble though.
Old Apr 19, 2012 | 12:07 PM
Never-Enough's Avatar
Never-Enough
What compact jacks, that don't cost a fortune & are fairly easy to find, work w/our cars?
I want to get rid of the run flats, but after getting rid of them in my BMW & getting a flat after, I'm not too sure.
Old Apr 19, 2012 | 12:27 PM
Seadawg's Avatar
Seadawg
I went over 20 years without a flat, then got a vette in 2008 and have had 4 flats since then. All repairable, but it sure was nice to go on into work, call up the repair place, then drive by and get it fixed with no damage.
I've continued to stay with runflats, since mine is a daily driver.
