carbon engine build up C6
The A6 transmission will automatically match revs on downshifts (with/without the use of the paddles)...
this may be what you are experiencing when slowing down. When accelerating, don't completely mash
the throttle, but instead roll into it quickly & firmly to avoid the "lag" in the gear selection.
What do you mean by mash the throttle instead roll into it quickly?
Condition/Concern:
Some customers may comment on a flare or harsh 2-3 shift.
Recommendation/Instructions:
This condition may be caused by leaking 1-2-3-4 and 3-5-R clutch fluid seal rings (230). The following conditions are indications that the fluid seal rings may be leaking:
• Delayed/extended or delayed with harsh feel initial Park to Drive and/or Reverse to Drive shifts, that are more likely to occur when the transmission temperature is below approximately 40 degree C (104 degree F).
• Harsh or flaring 2-3 shifts that are more likely to occur when the transmission fluid temperature is in the approximately 0 degree C (32 degree F) to 40 degree C (104 degree F) temperature range, but can be present at any temperature.
• Harsh 2-3 shifts that are more likely to occur at less than 50% tp.
Vehicles built in the January through August, 2007 time frame are more likely to have leaking fluid seal rings
Important: When inspecting the 1-2-3-4 and 3-5-R clutch fluid seal rings (230) there probably will not be visible signs that the seal rings are damaged.
If any of the conditions above describe the flare/harsh 2-3 shift condition replace the 1-2-3-4 and 3-5-R clutch fluid seal rings (230), DO NOT replace the valve body or TCM.
Stomp> Petal to the Metal as long as you can,at less to 100mph.
