Is there any way to reduce the volume of ....
Received 1,029 Likes
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
...the beep when making selections and choosing the options on the DIC? It's pretty loud and annoying.
I know, I know...in the grand scheme of things, it's an unimportant issue...but if it's possible to make that puppy not bark so loud, I'd like to know about it.
TIA...
TIA...
TIA...
TIA...
Chime Level Adjustment
The radio is used to adjust the vehicle’s chime level.
To change the volume level of the chime, press and hold
pushbutton 6 with the ignition on and the radio power
off. The volume level will change from the normal
level to loud, and LOUD will appear on the radio display.
To change back to the default or normal setting,
press and hold pushbutton 6 again. The volume level
will change from the loud level to normal, and NORMAL
will appear on the radio display. Only one chime will
be heard when changing from the normal to the
loud setting. Each time the chime volume is changed,
three chimes will sound as an example of the new
volume selected. Removing the radio and not replacing
it with a factory radio or chime module will disable
vehicle chimes.
If you switch the Front and Rear outputs (thereby reversing the fader) the chimes will be behind you (from Front Left to Rear Left) so that's an improvement, and can be further lowered if you are using a line-driver or amp and cut-down the rear db's ...
vehicle chimes.
vehicle chimes.
Well I'll be jiggered! You learn something everyday here!
TIA...
TIA...
Received 2,051 Likes
St. Jude Donor '13
Our 2006 was annoyingly loud, our 2009 is barely audible.
Both had the Bose radio/nav
