Broken Seat
Old Apr 23, 2012 | 07:13 PM
carllangford's Avatar
carllangford
Default Broken Seat
I noticed yesterday, all of a sudden, there was an uncomfortable feel about sitting in the drivers seat. It feels like the seat is cockeyed and leaning in towards the console.
I discovered today that the hinging between seat back and the seat bottom on the console side is broken.
What are my options? Any idea how much $$
Old Apr 23, 2012 | 08:19 PM
grady's Avatar
grady
had 600 miles on my 2012 when it broke. Dealer fixed under warranty. Had to replace entire seat. Good luck...
Old Apr 23, 2012 | 08:27 PM
carllangford
I'm at 60K with an '05 and way out of warranty
Old Apr 24, 2012 | 07:09 AM
carllangford
Anybody? Can you just replace the seat frame?
Old Apr 24, 2012 | 05:50 PM
carllangford
From a visual inspection of the seat and examination of the diagram in http://store.gmpartshouse.com/parts/...agramCallOut=9 I suspect part # 9, the Pivot Bracket.
Anyone have the procedure for removing the seat (with airbags)?
Old Apr 24, 2012 | 06:34 PM
ErnieN85's Avatar
ErnieN85
disconect the battery wait 1 min (minimum) unbolt and unplug the seat. disconect the seatbelt , cover the door sill pickup seat (works better with the roof out)
Old Apr 24, 2012 | 06:51 PM
CO Lightfoot's Avatar
CO Lightfoot
Originally Posted by carllangford
...Anyone have the procedure for removing the seat (with airbags)?
Step-by-step instructions with pictures:
http://forums.corvetteforum.com/c6-z...ml?ref=esp-img
Old Apr 24, 2012 | 07:37 PM
carllangford
Thanks guys. I'll save a boatload of $.
Old May 3, 2012 | 05:25 PM
carllangford
The Pivot Bracket (Part # 10272746 ) is on National Back Order with no ETA for the part to be released. What to do ?
I think I'm going to pull the seat and take a closer look. My initial inspection was with seat in the car.
It sux when it's your daily driver. Kind of limits you to when and what you can do. Right now the seat's shimmed with a folded up towel, LOL.
Old May 3, 2012 | 06:03 PM
BLD.70DRIVERMPG-RET.'s Avatar
Default just had my seat back frame replaced this week
On the same order. The lower tab had not broken but was bad. Dealer covered it under 3/36. The frame looks robust but in fact is not. Do not in the future put so much backward pressure on the seat back. When getting in and out I was told. Or cut back on the WOT!
Old May 3, 2012 | 06:05 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
sorry to hear/read this. on another note, this may be the time to repair and add to the seating area per that kit that's offered for around 70. hope that national backorder gets fixed soon.
Old May 8, 2012 | 09:56 PM
carllangford
Well I had ordered two parts, one of which was on back order, and "something" has shipped and is due in tomorrow. I hope it contains both
[Edit] It did contain both. Now let's hope I ordered the right part...... I have doubts after looking at it....
Old May 11, 2012 | 08:44 PM
carllangford
I took out the seat (thanks for the instructions) and it's way worse than I thought. Looks like I need a new seat-back .
Here's a video of the seat: http://www.youtube.com/playlist?list=PL66FF4F947B45D285
Worse yet I don't see the seat back listed as an available part @ PartsHouse, at least not for the heated seats. (See Item #6 in http://store.gmpartshouse.com/parts/...iagram=CF05340).
They do list a seat back for the non-heated seats: http://store.gmpartshouse.com/parts/...iagram=CF05335, Item #3. It's $134. From the two diagrams they both look to be the same, which would make sense.
Oh, and I'm not a heavy guy...... Maybe previous owner was?
Old May 14, 2012 | 02:11 PM
carllangford
Took car & video to dealer. $300 labor + $180 parts. Looking at the job maybe $300's not so bad..... It probably doesn't take that long but the learning curve is what kills so much personal time.
Has anyone else had this happen to their seat?
Old May 14, 2012 | 02:17 PM
johnodrake's Avatar
johnodrake
Moderator
Start calling junkyards to see if they have a wreck you can buy the seat out of.
Old May 14, 2012 | 02:24 PM
carllangford
Nice idea. Do you think it needs to be an '05 seat?
Old May 16, 2012 | 01:31 PM
carllangford
I went ahead and took her to the shop. When the tech pulled the skin off the seat back this is what he found:
http://share.shutterfly.com/action/w...AbuGbRi4Ys2bqY
To fix (extra $90) or not to fix? If I have it fixed I get new seat back foam.
To Broken Seat
Old May 16, 2012 | 03:03 PM
bonnevillebill's Avatar
bonnevillebill
Lose some weight! (Just kiddin')
Old May 16, 2012 | 05:12 PM
CO Lightfoot
As long as it's apart, I say Fix It.
Also consider replacing the seat bottom foam with an upgraded version:
http://forums.corvetteforum.com/c6-c...9-shipped.html
Or at the very least, upgrade the seat bottom with this $40 Rebuild Kit:
http://forums.corvetteforum.com/c6-c...-kits-jwm.html
Old May 16, 2012 | 06:19 PM
Wildmanht's Avatar
Wildmanht
LMAO... I was going to make the same joke...
