Stuck for a place to mount your GPS?
Want to keep the windshield free?
Don't want to block access to the AC control?
Still want use of both cupholders?
Want access to both driver and passenger?
Need to swap it from car to car?
Here's the BEST answer to all those problems.
Snugly fits into either cupholder and rotates as desired.
A foam spacer is included for larger style cupholders.
Does the GPS unit shake or vibrate using this product?
Any photos of the product alone (no GPS, uninstalled)?
Thank you for becoming a supporting vendor!
I've experienced no shake, rattle, or vibrating in the several cars/trucks I've used these in for the past 2 years. It's a very snug fit, especially in a Vette.
It's a rather simple device that securely puts the GPS unit within easy reach, yet easily adapts to other vehicles.
I have the spray can lids modified to fit in my cup holder to serve as the same type of mounting, but I lose the ability to use that particular cup holder. HOOXOH has the better solution, as it allows you to place the NAV out of your line of sight while driving, yet is easy to see/use along with being able to use both cupholders.
Yes, and the fingertip access makes it easy to search for fuel, food, hotels, etc. without a long stretch or removing your seatbelt.
Any issues with intermittent satellite reception with the GPS unit mounted on/adjacent to the console or at/near floor level in one of your photos ?
Thx
Thx
No problems in the several cars I've used it and no reports of anyone else having reception issues either. This has been in use for several years with no complaints regardless of the car or GPS unit being used.
Thx
I have My Garmin mounted low like HOXXOH does with his mount and have no reception problems in My C6 Z06 or my DD Mercedes sedan.
The problem is now to look at the GPS you have to look down and take your eyes off the road. I still can't believe there are states like MN where it's against the law to put anything in the windshield.
