Active Handling Problem
http://forums.corvetteforum.com/c6-z...ng-recall.html
then you can do a search for 'Service Active Handling' and read for the next two days straight on others problems,suggestions,solutions.
fyi... could you edit your post to state year / model and any mods done, telescoping steering column or not, plus any work done it on lately, ya know, more details , might help a little
http://www.alldatadiy.com/TSB/10/061006fZ.html
see in above for...
10118 APR 10 Recall - Service Active Handling System Message
06-02-35-002B OCT 07 Electrical - Service Active handling Message/DTC C0710
I had the SAH code right after my winter storage this year on my '07 coupe and it turned out to be the harmonic balancer that caused the code.
Don't take a chance with your car
part... http://store.gmpartshouse.com/parts/...icleid=1432065
instructions to do the tsb if you have that problem and not covered but i think you are,
http://s680.photobucket.com/albums/v..._AV8R/?start=0
Your recall is
Campaign Number 10V17200
Vehicles Affected built during March 2004 and January 2006
w/Tilt and Telescoping Column
Chevrolet 1-800-630-2438
So, if your car is not in that build date, then you have no recall. Get the code scanned and proceed from there.
Last edited by ChevyDave; May 3, 2012 at 11:53 PM. Reason: dates for car recall....
I'm sorry you are having a Service Active Handling System message. If you want to send me a private message with your VIN I can check to see if you have any open recalls for this.
Evan, Chevrolet Customer Service
