How long does your clutch fluid stay clean????????????
This is a much under-appreciated fact of life with hydraulic fluid. It is the reason why hydraulic fluid reservoirs are transluscent. You can see the fluid level without opening the reservoir and exposing the fluid to humidity.
I flush it until it is clean, usually about 3 or 4 times. I use the Prestone fluid, and buy a new container for every oil change.
I also put in a bottle of fuel injector cleaner in the gas every oil change too.
07-07-31-001A: Clutch Hydraulic System - New Service/Owner Maintenance Information - (Sep 11, 2008)
Subject: Clutch Hydraulic System -- New Service/Owner Maintenance Information
Models: 2005-2009 Chevrolet Corvette (Including Z06 and ZR1) with Tremec 6-Speed Manual Transmission (RPOs MM6, MZ6, MH3)
This bulletin is being revised to update the models to 2009. Please discard Corporate Bulletin Number 07-07-31-001 (Section 07 -- Transmission).
This bulletin is being issued to provide dealers with additional information on servicing the clutch hydraulic system.
Please also advise customers of this new maintenance information.
Some cases have been found where the vehicle's clutch hydraulic system was contaminated with water.
Higher than expected levels of water in the clutch fluid greater than 2% may cause the clutch fluid to boil.
The presence of water in the fluid lowers the boiling point significantly; when this occurs, the driver may lose customary clutch pedal feel and performance.
To eliminate the opportunity for moisture to enter the clutch hydraulic system:
• The clutch fluid level inspection should be a VISUAL inspection only.
Look through the transparent reservoir and observe the fluid level.
Avoid removing the cap !
DO NOT remove the cap just to top-off clutch fluid. Leave the system closed and sealed.
During PDI inspection or routine service, the cap should not be opened for just an inspection.
• Open containers of DOT 4 clutch fluid have a two week shelf life.
DO NOT use fluid if the container opening date is unknown or older than two weeks. DO NOT mix or re-use old fluid. Current service information already covers the issue of reuse.
• To provide the best clutch operation, it is recommended that the owner change the clutch fluid every two years.
Please flush and replace with P/N 88958860 (P/N 88901244 in Canada) or equivalent DOT 4.
How fast does brake fluid absorb moisture?
It depends on the fluid and environment. A typical high performance DOT 4 fluid like, Motul, AP, Castrol SRF, Wilwood and ATE SuperBlue, in a high humdity evironment will absorb as much as 4.5-5% moisture in as short a period as 2 weeks. In real world testing (several daily driver cars, Prospeed GS610™ absorbed <1% moisture in 3 years. This was measured from the brake fluid in the resevoir where the vehicle's brake system is most likly to contain the greatest contaimination of moisture.
How does brake fluid become contaminated?
Water/moisture can be found in nearly all brake systems. Moisture enters the brake system in several ways. One of the more common ways is from using old or pre-opened fluid. Keep in mind, that brake fluid draws in moisture from the surrounding air. Tightly sealing brake fluid bottles and not storing them for long periods of time will help keep moisture out. When changing or bleeding brake fluid always replace master cylinder caps as soon as possible to prevent moisture from entering into the master cylinder. Condensation, (small moisture droplets) can form in lines and calipers. As caliper and line temperatures heat up and then cool repeatedly, condensation occurs, leaving behind an increase in moisture/water. Over time the moisture becomes trapped in the internal sections of calipers, lines, master cylinders, etc. When this water reaches 212º F the water turns to steam. Many times air in the brake system is a result of water that has turned to steam. The build up of steam will create air pressure in the system, sometimes to the point that enough pressure is created to push caliper pistons into the brake pad. This will create brake drag as the rotor and pads make contact and can also create more heat in the system. Diffusion is another way in that water/moisture may enter the system.
Diffusion occurs when over time moisture enters through rubber brake hoses. The use of hoses made from EPDM materials (Ethlene-Propylene-Diene-Materials) will reduce the amount of diffusion OR use stainless steel braided brake hose with a non-rubber sleeve (usually Teflon) to greatly reduce the diffusion process.
. But your point that brake fluid is hygroscopic (readily absorbs moisture) is a valid one My final point is contamination can be as bad as moisture, and the only way to get rid of both is with a FULL BLEED job, not just the reservoir. DO NOT procrastinate longer than 2 years on that folks. But sooner, especially the first time, is highly advisable.
It sets up for me to mess up making more of a mess.
Brake fluid being as corrosive as it is has me very focused when using it.
. Booyah !
