Tilt sensor install ($20)
Old May 4, 2012 | 09:23 PM
RainMan12's Avatar
RainMan12
Default Tilt sensor install ($20)
gone
Old May 4, 2012 | 09:41 PM
ChevyDave's Avatar
ChevyDave
awesome!!!! i dont know how hard it would be, but the color wire diagram and the actual color of wire you used are different. i think i understand, any way you could redo the diagram, would help others.
awesome job!!
Old May 4, 2012 | 09:58 PM
Slare's Avatar
Slare
Not a big concern of mine, but I will give props where props are due this is awesome information. Stuff like this makes a forum.
Old May 4, 2012 | 10:22 PM
RainMan12's Avatar
RainMan12
The reason I wanted a tilt sensor was mainly to try to prevent wheel theft, though I have also ordered a set of Gorilla locks. I just never understood why GM didn't put a tilt and/or shock sensor on the car at the factory. In my opinion, it really should have one as standard equipment. All the export Corvettes get them, but they don't put them on the US model cars. Makes no sense to me.
Old May 4, 2012 | 10:28 PM
ChevyDave's Avatar
ChevyDave
awesome job... three cheers for the RainMan!!
hummmm, so i wonder if you might get some cash if you send your idea to a mod company. $20 in parts, i could see them selling for $120
it would be be worth it to me
Old May 4, 2012 | 11:16 PM
franman69's Avatar
franman69
Old May 5, 2012 | 12:23 AM
Johns94Z's Avatar
Johns94Z
Old May 5, 2012 | 10:57 AM
Landru's Avatar
Landru
Valid reason, especially if the car's parked outside/alone for any length of time.
Had assumed these kinds of sesors were incorporated into the security system on Corvettes for years. Now to learn they aren't. Alot less cars come with these as SOP. Chevrolet really dropped the ball.
Nor me.
Nicely done write-up.
Old May 5, 2012 | 11:14 AM
RainMan12's Avatar
RainMan12
One other quick little note I'd like to add. When you're hooking this all up and testing it, I'd highly recommend connecting the battery to a charger. I ran mine down nearly flat trying to test it out. It was a four year old battery, so it's not a big deal, but flashing the lights and horn draws more current than you realize.
Old May 5, 2012 | 11:32 AM
DubsAndSubs's Avatar
DubsAndSubs
So when the sensor trips the alarm, how long does the alarm go for and how do you turn it off?
Old May 5, 2012 | 01:30 PM
RainMan12's Avatar
RainMan12
I haven't actually timed it, but I think it's about 90 seconds, and then it automatically resets. You can turn it off by pushing the UNLOCK button on your remote.
Old May 5, 2012 | 02:18 PM
DubsAndSubs
Awesome, thank you for doing all the ground work for the rest of us! Definitely on my to-do list now
Old May 5, 2012 | 06:52 PM
kedar's Avatar
kedar
St. Jude Donor '12
Nice!
Old May 5, 2012 | 07:08 PM
phileaglesfan's Avatar
phileaglesfan
Great work! GM does get cheap at times. My Yukon didn't come with it also but GM has accessory for $100 but dealer has to program it.
Old May 5, 2012 | 09:01 PM
Thrill6's Avatar
Thrill6
Which relay are you using? Where did you purchase it along with the connector?
Old May 5, 2012 | 09:36 PM
VET4LES's Avatar
VET4LES
Great job. Thanks for sharing.
Old May 7, 2012 | 05:25 PM
victorf's Avatar
victorf
I'd rather see forum members save the money and do it themselves. Its a very easy mod, and the is no reason to spend a lot of money on it.
My next project will be to see if I can install this $6 dual zone shock sensor.
http://www.amazon.com/Install-Essent.../dp/B0009SXOTC
Just an FYI, the Stinger I have on two cars have became undependable!
I did my own wirings and have always solder my wires.
To Tilt sensor install ($20)
Old May 7, 2012 | 06:07 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
cool good job
Old May 7, 2012 | 06:57 PM
Thrash's Avatar
Thrash
Great tip and thanks, as said, this is why we are here
Old May 9, 2012 | 02:13 PM
B-Myster's Avatar
B-Myster
First, here is the connection diagram:
Here is the sensor with relay wired up ready for install
Here is the connection to the wiper/ACC fuse
And here is the sensor located in the car
In the diagram picure there is a red wire going to the wiper/ACC fuse and in the actual picture of the relay the wire is yellow. The next photo shows the connection to the wiper/ACC fuse and the wire is red and in the final picture I see the yellow wire again coming from the relay. What is the yellow wire connected to? I'm guessing you spliced a red wire to extend the yellow wire since the 2nd picture only shows 1 red wire?
