Climate Control throws code EB
Old May 6, 2012 | 07:17 PM
bigearl56's Avatar
bigearl56
Default Climate Control throws code EB
Took the wife on a mini vacation this weekend with the '06. All of a sudden I could not control the temperature with the *****. The window was blank except for the letters EB. I stopped for lunch and when we started up everything was fine. Anybody else have this happen? My concern is why did this happen and will it occur again on a 95 degree day?
Earl
Old May 6, 2012 | 07:47 PM
ChevyDave's Avatar
ChevyDave
well, no luck with my search for the HVAC code list yet.. did come across this, which isnt really any help, but found interesting. If i find the code list i'll post. (i did find the list for 1996 and earlier)
HVAC Reset C6 Corvette
Press and hold these 3 buttons (ignition on, engine off):
Front Defrost
Rear Defog
Fan Up
fyi: Its my understanding that DTC codes will be set, but they are TECH II type that autoparts stores cant read.
note: i give up,found no code list
Last edited by ChevyDave; May 7, 2012 at 10:49 PM. Reason: dtc code(s) are set which can be read
Old May 7, 2012 | 07:27 PM
bigearl56's Avatar
bigearl56
Default Thanks
Thanks ChevyDave. Will try that next time if she don't reset herself.
Earl
To Climate Control throws code EB
