NPP help
Old May 7, 2012 | 08:11 PM
RT2SJB's Avatar
RT2SJB
Default NPP help
I have an 07 A6 and am considering adding dual note exhaust but have a question I need help with first. If I add the mufflers will a "mild to wild" switch controll them? As you know this year did not have the system.
Old May 7, 2012 | 08:14 PM
Thomasmoto's Avatar
Thomasmoto
What you need to do is buy the NPP in the box kit. It comes with a controller if I recall correctly.
Old May 7, 2012 | 08:23 PM
tim414's Avatar
tim414
St. Jude Donor '12
The NPP in a box should have the mufflers which have flaps and the other peripherals required to control said flaps. Then, all you need to do is get the m2w or just pull the fuse if you want them open (loud) mode all the time.
RT2SJB's Avatar
RT2SJB
Default I did not know
If i need to buy anything else to make the system controll the valves since this was not built into the original system.
Old May 7, 2012 | 08:38 PM
RT2SJB's Avatar
RT2SJB
Default I understand
but I have no fuse to pull, that is my concern. My car came with out any of the vacum lines or electronic controlls for these mufflers. I am thinking the kit comes with the vacum lines and the electronic controlls to make them work.
Old May 7, 2012 | 09:57 PM
A Man and his Vette's Avatar
A Man and his Vette
I just bought NPP mufflers and NPP in a box for my '07. That is all you need. Mine will get installed next week...
peter pan's Avatar
peter pan
Life Time NCM #2196
That is what I used when I installed my ZR1 exhaust
Old May 7, 2012 | 10:07 PM
AtHomeSoda's Avatar
AtHomeSoda
Default ah...
I put NPP on my 06. It is easy... You just need to put on the NPP Cat Back Exhaust, and the NPP in a box, it has the vacuum lines and controllers. You will love it.
Old May 7, 2012 | 10:32 PM
franman69's Avatar
franman69
Just remember you need a takeoff NPP from a 2008.. Later than that won't fit over the exile without some modifications...
Old May 7, 2012 | 11:00 PM
boraxman's Avatar
boraxman
Unless you also use 2009 up mid pipes
Old May 7, 2012 | 11:22 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
Most NPP in a box controllers work either open or closed. I use the system from http://www.sunsetorangecreations.com/ a vender here .
His system will work like the factory NPP with the valves opening at a set RPM or can be set open all the time or closed all the time
Old May 8, 2012 | 08:27 AM
MikeBravo56's Avatar
MikeBravo56
St. Jude Donor '12-'13-'14
Multiple ways to get NPP. I have an 07 A6 coupe with modded Z06 NPP mufflers with the M2W remotes. Wakes my neighbor up every morning
To NPP help
