5th Gear
Old May 7, 2012 | 10:13 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
Default 5th Gear
I have a 2012 GS A6. I drive in manual mode most of the time. What I find when down shifting from 6th to 5th is that 5th seems like it has 2 gears. I can watch the tach and feel the way the car shifts and feels like it is downshifting again while in the same gear. Anyone else have this problem?
Old May 7, 2012 | 10:43 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
no, but I don't have an A6. j/k. here's a bump so some others might see it.
Old May 7, 2012 | 10:53 PM
Gary '09 C6's Avatar
Gary '09 C6
computer-controlled rev matching on the downshifts (happens on any downshift with the A6)...?
Old May 7, 2012 | 11:49 PM
fnsblum's Avatar
fnsblum
Torque converter lock/unlock? Later! Frank
Old May 8, 2012 | 08:58 AM
MKenM's Avatar
MKenM
I thought the same thing but should it happen on acceleration?
Old May 8, 2012 | 12:09 PM
DigitalWidgets's Avatar
DigitalWidgets
The rev matching feature occasionally creates some unusual shifts for me in certain situations. I think experience has taught me some better "technique" to avoid those anomalies. Otherwise, I haven't noticed what you're mentioning in 5th (consumate paddle shifter here!).
I must say, I love the seamless power as you paddle shift up through the gears during acceleration from 0 to cruise speed with that A6!
Old May 8, 2012 | 12:12 PM
michaelinmech's Avatar
michaelinmech
Big Brother intervening
Old May 8, 2012 | 02:44 PM
MisterMidlifeCrisis's Avatar
MisterMidlifeCrisis
I think the lockup happens in gears 2 through 6 after a couple to a few seconds of low to moderate throttle at lower engine speeds. I've never noticed it happening at higher engine speeds and zero to very light throttle such as when downshifting and then just breathing on the throttle to maintain handling balance. It might also be that it won't lock up once cornering forces exceed some limit.
But what you are feeling is normal. You'll probably also notice that once it locks up, a paddle shift takes longer to accomplish, as the transmission has to unlock before the shift. Now that I've said that, it'll probably start bugging you. Sorry!
To 5th Gear
