Mild to Wild controller - which one
I noticed there are at least two forum members selling different kits and I was wondering what CF members who had purchased either one thought of them.
Any pros or cons of one versus the other?
The only real requirement I have is that I would love to operate the switch from the garage opener gear on my visor (I belive it's called Homelink). I think one kit does this, not sure about the other.
Also, any special concerns on mounting the box? Trunk vs under-the-car?
Tx in advance for your help.
It installs without drilling and has many different options for controlling the butterflies, it also has a lifetime warranty. Install instructions are available at www.sunsetorangecreations.com
The Exhaust Commander All-in-1 NPP retrofit kit.
Also, check out our new controller option available with our NPP retrofit kits.
The Exhaust Commander Elite NPP retrofit kit.
It lets you use your door lock button or your Corvette's keyfob as the controller!
http://www.qpcpv.com/topflightreproductions/index.html
Free E-Z TAP now for the LS2 and LS3 and exclusive to our NPP in a Box product! We always suggest mounting inside do the security of mounting and damage from road debris. Both companies kits show mounting in the car and the preferred way, 2 simple holes and you’re done, you can mount ours outside also, many have done it on the forum, your choice”
E-Z Tap allows you to simply tap the vacuum from the front of the plenum in less than 3 minutes. No removing coil packs, busting knuckles or trying to access the back of the plenum. E-Z Tap make install a dream instead of a nightmare.
Always 100% ZERO drain and you choose the startup mode HAVE IT START OPEN OR HAVE IT START CLOSED and can change it anytime. We guarantee this system to be the easiest to install and best engineered or your money back.
To order: http://www.qpcpv.com/topflightreproductions/index.html
Use what the PRO's use - Thanks to LG, ECS, Vette Doctors, Corvettes of Westchester, Corvettes of Houston and the many other Chevy Dealers for choosing this system to install in their customers cars, they demand the best and so should you. If you have any concerns or questions about the quality or ease of installation feel free to call them an see why NPP in a box is their choice.
VetteDoctors (Carmen) “Your NPP system is the best on the market. Very easy to install & your service is second to none.”
East Cost Supercharging(Chris) “We installed one last week and I must say the product was very well put together and a smooth install.. Thanks”
Corvettes of Westchester(Chuck) "I can't say enough about the NPP in a box PRODUCT! The kits are first rate! EVERYONE wants them! PRICE IS AWESOME!
SHIPPING IS ALMOST INSTANT! What more could you want!?!?"
Cheap, reliable, easy to reach, no fob to lose or battery to replace.
This is a great vendor and Ben will return your calls asap if you need help with install.
And I couldn't agree more enthusiastically.The original Mild2Wild has a great and untouchable track record by any similar device that came after it's debut...the market facts show:
-Corvette museum installs it on new deliveries
- Macmulkin Chevy (forum vendor) installs it on every Z06 or car they sell with NPP
- Choice of Jay Leno and reviewed on his site
- FCC certified
- GM dealer certified
- Is the first controller developed in Sept 2006 and was developed with aid of GM engineers
- Used by Scott Dixon, an Indy 500 winner
I have had the NPP in Box in my 2006 C6 Coupe since it was introduced and it has been flawless to this day. Product quality, longevity and value is built in to all their products and they are backed with class leading customer service.....that's why you can't go to the Corvette Museum, a car show, or our forum vendors websites without seeing the Mild2Wild or any of the manufacturer's other great products!
- FCC certified
I said the same thing but seems like my post was deleted. Your dead on 100%
