It seems that many on the board use detailing spray between rides to clean up their cars. I understand that it's quicker than a wash, but without the benefit of a thorough wash and rinse, aren't you just pushing the grit around and ultimately going to result in scratches to the finish?
I guess it depends on how dirty the car is. For me, my routine after a drive is to use a California Duster and then use some Quick Detailer for areas that might need a little more attention (the back end usually gets the most attention). I always use clean micro-fiber towels to try to minimize swirling and scratches but ultimately, its inevitable that swirling will happen regardless of how you approach it. My goal is just to minimize the amount of swirling that will occur.
Used correctly ... I don't think that is a concern. I use detail spray in-between washes or just to remove bugs
I use 2 clean microfibers (one for each hand) and liberally spray each one with detail spray (this lubricates the microfibers) ... then I spray a small area of the car with detail spray and work my way around, doing small sections at a time. I do all the upper surfaces first, then doors, rear and lastly the sections around the wheels (by far the dirtiest areas). I probably use 6 microfibers in total doing the car.
A performance car / detailing shop in town told me about this technique. Also told me to NEVER use a California duster ... because of the lack of lubrication.
No complaints here ... the car looks great afterwards and it only takes maybe 5 minutes.
California duster first, always (not on hot paint). This is after dry driving only, if the car has been driven in rain I will always wash.
I have used a CA Duster for years with no ill effects, as long as you dont press down and allow it to glide over the surface it will not cause any harm. I also take mine and use the air hose and blow the dirt/dust out about once a month.
As said if the car is clean than a microfiber towel and detail spray will not hurt a thing.
I use detailer spray to remove all the little things that don't look nice (or might mar the finish if left on) but don't merit washing the car. On Sunday, I hit a bird, and the little bit of residue on the fascia came right off with detailing spray - no blood or anything...
Ok, I've been wanting to vent this for a while. Every time I go to a show and breakout my car duster or quick detailer some f**k**g "expert" stops by to tell me that I'm ruining my paint job with the products I'm using. Yet, with all their extensive knowledge, they can't seem to agree on what the best way to clean a car is (other than to get it painted and then lock it in a sealed room forever).
My apologies to all the true experts out there but I seem to always run into the world best painters and detailers at every event. I'd be surprised if they even owned a car.
3 times I've heard "Only use warm water and a soft diaper" Like I go the a show with 50 feet of hose and a bucket?
No not at all. I rarely wash my car. I use detail spray every time I drive my car.
I use the same philosophy with Detailer and the Duster too. It's a judgement call really... if the car just has some light dust or a small patch of "dirty" somewhere on the car..spray liberally and use a very good microfiber...don't press down hard, lightly wipe and no worries...
I usually find for my comfort level...the first couple days after I wash the car, I will use detailer to keep it very clean, but beyond that time frame I stop using it as its time for a wash again
I must be frustrated today?
it happens, I've had that too..I just ignore them depending on how they approach me...there's always some tool who think's he's an expert.
there are some good threads on here in the car care section where vendors will offer advice, or approaches on how to care for the car..take a peak if you like
First I thoroughly wet a micro towel and then wring it out then gently pass it over the car constantly refolding the towel so that only clean damp towel surfaces touch the paint, After I finish doing that I discard the towel and use detail spray and a fresh clean micro towel and detail the car.
Ultima Waterless Wash Plus+ Concentrate is a super hyper concentrate that can be used to make the Ultima Waterless Wash Plus+ spray wash solution or as a no-rinse car wash formula in a bucket. Either way, Ultima Waterless Wash Plus+ will meet and exceed your expectations in cleaning ability as well as slickness and gloss enhancement! http://www.autogeek.net/ultima-water...ncentrate.html
I've been using detail spray on my cars for two years now. No marks no scratches. Don't use it on a hot car or in the sun. Seems to work much better than just water. Naturally don't use it on a very dirty car, but dusty or rain marked is fine.
A Cali duster, some detail spray and microfiber towels are the least of our problems. Every time you take the car out, you are driving it through a slurry of airborne grit. The wind kicks it up, its flying off the tires of the car in front of you. I use the winter months to polish out any ultra fine scratches and swirls and by far most of those are just on the front of the car.
On my silver C6 I use Meguires NXT detail spray and Zaino cloths to detail the car between washes. I wet one towel to wipe off the dust, then use the spray for shine.
No matter what you do to the car, you are at risk of putting fine scratches in the clear coat every time you touch it. Don't worry about it. Mine come out very easily with my DA polisher and a light polish.
Well said. Just driving the car does more damage than anything you can do removing dust. My windshield looks like it has been sandblasted.
