Tire Size
Old May 12, 2012 | 08:34 PM
Local Pro's Avatar
Local Pro
Default Tire Size
Has anyone played with changing the rear tire size on a base C6? Either to play with gearing or visual appeal. I like the look of a tire that "fills up" the wheel well and gives a nice stance to the car, but don't want to mess up performance. Anyone that can help me out with a little real world experience would be appreciated.
Old May 12, 2012 | 08:59 PM
gee350z1's Avatar
gee350z1
If wider is what your looking for then that certainly can be accomplished.You would have to get wider wheels though which is obvious. Are you looking to just put bigger tires on your stock wheels ? my rears are 20x11 wheel with 325/25/20 size tires with a 79mm offset. really fills the wheel well.
Old May 12, 2012 | 09:58 PM
Local Pro's Avatar
Local Pro
would like to stick with the 19x10 wheel on the back. With clever tire sizing you can add a deceptively larger look. I like the "that car seems stock, but there is something different about it" look.
Old May 12, 2012 | 10:10 PM
shootincyclone's Avatar
shootincyclone
St. Jude Donor '12-'13
305's are about as wide as you can get on the factory 19'' rears
Old May 12, 2012 | 11:26 PM
Vegasr's Avatar
Vegasr
295s might be the sweet spot with little to no ill effect
Old May 13, 2012 | 05:47 PM
Local Pro's Avatar
Local Pro
thanks for the info guys, I talked to a friend at a tire shop and he will mount a 295 and a 305 for me to see which I like better.
Old May 13, 2012 | 06:03 PM
Mad*Max's Avatar
Mad*Max
sorry for my ignorance, but would these be legal, I would also like the look of a wider tire in the back as long as I won't get hassled by the cops, who are extremely vigilant in my neighbourhood
Old May 13, 2012 | 06:06 PM
Mad*Max's Avatar
Mad*Max
also, would run flat be available?
Old May 13, 2012 | 06:16 PM
Local Pro's Avatar
Local Pro
the rebel in me likes the illegal aspect that I had not even considered. I guess I must be lucky because in my area you would never hear anything about the width of your tires. It's not uncommon at all to see lifted diesel trucks with huge tires sticking out 6 inches on each side of the truck blowing black smoke all over town and the po-po never pay them any attention
Old May 13, 2012 | 06:22 PM
Mad*Max's Avatar
Mad*Max
I guess they have bigger fish to fry
Old May 13, 2012 | 06:29 PM
Local Pro's Avatar
Local Pro
literally
Old May 13, 2012 | 06:35 PM
9157's Avatar
9157
Naples FL
Will changing tire size affect speedo/computer? If not what is the largest front and rear size on stock rims? Full specfication if possible...
Old May 13, 2012 | 06:54 PM
TLS_Addict's Avatar
TLS_Addict
Lower the car? You can figure out the variation in your speedo pretty quickly with math. You will find more variation sometimes with worn vs. new tires than changing sizes.
Yes...cant answer the rest as it would be tire specific.
To Tire Size
