iPhone/AUX advice?
Old May 12, 2012 | 10:23 PM
jb_va2001's Avatar
jb_va2001
DC Area Events Coordinator
Default iPhone/AUX advice?
I'm shopping for a used C6 and I'll want iPhone/AUX music connectivity. What do I need to know? Any Advice?
Did GM add iPhone/AUX during a certain year or with a trim package? Was it always an add-on accessory? Should I get a GM PAL or third party connector?
Thanks in advance.
Cheers,
JB
Old May 12, 2012 | 10:31 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
In 2008 an auxiliary jack was added to the single disc and six disc cd radios. This will allow playback from any device with a 3.5mm audio jack.
In 2010 a USB ( iPhone, iPod, thumb drive connectivity) along with an auxiliary jack was added to the navigation radio.
As far as aftermarket if you find a car you like that is not in the short list above), you need look no further than forum member Ray Kawal's interface for the GM PAL (Personal Audio Link) for your mp3 playback needs.
http://www.kawal.net/PAL%20Rev%202.htm
Old May 12, 2012 | 10:35 PM
johnsub's Avatar
johnsub
If you by a C6 with Nav you can easily convert the xm to an ipod connection with a cable sold by Ray kawal for about $35 bucks i believe. I hooked up mine in about 20 minutes. Good luck
Old May 13, 2012 | 08:59 AM
B-Vette's Avatar
B-Vette
I'd forego the stock radio, (if you get an older C6) and get a third party receiver with all the connections and better nav.
Old May 13, 2012 | 09:55 AM
UmX's Avatar
UmX
I have a 06 with the nav can i use a newer stock nav in it? as long as i go to the dealership to have them link it?
Old May 13, 2012 | 01:41 PM
Flame Red's Avatar
Flame Red
Just ditch the stock radio.
To iPhone/AUX advice?
