Runflat IS Flat HELP!
Old May 14, 2012 | 09:48 PM
TripleAstyle123's Avatar
TripleAstyle123
Default Runflat IS Flat HELP!
Hey all! 08 Z-51 stock Goodyear Runflats 9k miles tread still decent but not great. I just had the left rear blow out for no apparent reason. Drove home 5-6 miles at less than 30mph. Correct me if Im wrong here- Assuming its on the tread and not too close to the sidewall it can be replaced with a patch style plug from what I have read on the forum.
Big question- If it is patched would it be ok for 1 full track day??? My 1st time going to BIR in MN. and I will have a professional driver showing me the lines and how to drive it correctly (Basics) before I take it out on my own.
Old May 14, 2012 | 09:57 PM
phileaglesfan's Avatar
phileaglesfan
I'm guessing it didn't blow out. If you are talking about a nail/screw then as long as it is not in the sidewall then you should be good to go, or right next to the sidewall in the tread. They should take the tire off the rim to fix it right which includes plugging/patching it.
As far as being good for the track I cannot answer that. Germans didn't plug/patch tires when I was there in the 90s because it would mean losing the speed rating (not good for liability on the autobahn). I wouldn't trust it on the track.
Old May 14, 2012 | 10:05 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Last I heard, Goodyear allowed one patch (internal) on a Corvette runflat and the tire retained its speed rating. A second patch, speed rating gone.
Is that a safe idea? Probably, but I don't know for sure.
OTOH, track days use up tires rather quickly, so you might want to patch the tire (if within acceptable limits) and kiss the Goodyears goodby after that weekend.
Old May 14, 2012 | 10:24 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Personal preference but I would never take a car to a high performance driving event with a plugged or patched trie, period.
You will be putting a lot of heavy duty stresses and heat cycles on that tire and a lot of faith in the mechanics of a plug and a lot of faith in the attention to detail of the person that did the work. Way too many variables for me to fell comfortable with at a track event.
Old May 14, 2012 | 10:44 PM
Wideout's Avatar
Wideout
St. Jude Donor '16
I noticed today that I had a screw in my rear left. It's not located on the sidewall. It is actually on the tread and not in between. Went to NTB and he said a runflat can't be repaired. I'm glad I saw this thread. I'm going to take it somewhere else and get a second opinion. I'll also look at previous threads. Thanks for posting this.
Old May 14, 2012 | 10:47 PM
talon90's Avatar
talon90
NCM Ambassador
Run flat tires can't be repaired if the puncture is on the sidewall. If it is on the tread, they are essentially like any other tire.
Old May 14, 2012 | 10:54 PM
Wideout's Avatar
Wideout
St. Jude Donor '16
Good to hear. Thank you. I'll stop by Firestone.
Old May 14, 2012 | 11:12 PM
Bill Dearborn's Avatar
Bill Dearborn
I would take the tire to a dealer or a Goodyear store that is certified to patch EMTs. Firestone run flats can't be used after being run when flat and a Firestone dealer may not know the Goodyear is different. The Firestone Runflats I had on my C5 were more compliant than the GY tires so the Firestone dealer may not have the proper tire machine to change the stiffer GY tire.
Bill
Old May 14, 2012 | 11:13 PM
category4's Avatar
category4
I would pass on a patched tire on the track, the consequences of a failure there are potentially catastrophic.
Old May 14, 2012 | 11:14 PM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
ditto.
ps. people........ patches are not speed rated..... tires are not subjected to the SAE or ETRO speed rating tests with patches...... just saying.......
Old May 14, 2012 | 11:18 PM
SanDiegoBert's Avatar
SanDiegoBert
Yep, I got screwed on my way back from Tucson, once. Got nailed while I was there, but I digress. Tire got plugged at a Goodyear shop, and that was 3 years ago. No problems since then.
But . . . It's a DD, not a track car. Quite a difference in thermal and elastic stresses.
Old May 14, 2012 | 11:19 PM
Bill Dearborn
Not really when running an EMT. Even if the patch fails the tire will lose pressure and the car will force a slow down to 55 mph. I just went through this two weekends ago when one of my tire pressure sensors failed and started reading 0 psi. The car immediately reacted by turning on Active Handling and applying the front brakes until the car slowed to 55. The guy in the BMW behind me almost ran into me when the car slowed so quickly.
I ran a patched EMT for ten track days when I first purchased my 08Z. Have also run patched tires EMTs on my C5.
Bill
Old May 15, 2012 | 12:27 AM
phileaglesfan
Slowing down from 70 mph vs 120 or more is a lot different. If a tire failed at the track it would probably fail at its weakest point which would probably be the repair and probably when it is under the most stress. The last thing you want is to lose all pressure in any tire while going into a high speed corner or braking hard.
I also lived in Germany for 8 years. Accidents at 100 mph or more are not pretty. A lot of them are the result of a tire blowout.
Firestones say do not repair on them. I know if I had a tire shop I would not repair one because of it. Not worth the liability
To Runflat IS Flat HELP!
