Keyfob Mystery
1 Post
Keyfob Mystery
Couple of weeks ago, my fob stopped working to start the car. With fob in my jeans pocket, it would let me open the door, but when I tried to start the car, I would get the "No Fob Detected" message until I took it out of my pocket and placed it on the console. Then the car (2011 GS) would start just fine. Thinking maybe it was a battery issue, I tried Fob #2; same deal. I could even open the trunk from clear across the garage, so the batteries seemed OK.
So I'm thinking: what changed? Then I recalled: my wife got a new phone and had to replace the charger in her CTS. Gave me her old one for the 'vette, which I plugged into the console power supply. Even though there's never been a phone connected to the charger, when I pulled the plug, the fob started working normally from my pants pocket. WTF?
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
Lots of devices will interrupt the communication of the FOB and the car. Some cell phones if in the same pocket as the FOB will do the same thing. Sorry, that charger will have to go.
Elmer
Elmer
the fob is funky!
that same thing happened to me today and you guys figured it out about the charger. I had plugged in my phone charger BEFORE starting the car, and I got the dreaded "No Fob..."
Now I understand!
Now I understand!
Even with nothing plugged into the charger there is current running through the transformer. This is where your interference stems from.
1 Post
Not that it would make a difference in this scenario, but I do wish Corvette would revamp their lighter/power outlets to switched power like our CTS, instead of always-on....
Hrmm interesting. I have the same issue but I usually put the key and garage door opener in the cup holder. I have a tag on my keychain anyways so I know its mine and it hangs out so I don't forget about it.
I'm gonna try to pull the charger out and start the car with the key in my pocket after work today. Good info.
Yeah, I had another look at the charger, and it's not a straight connection to the cellphone plug - there is what appears to be a transformer/fuse module right behind the plug.
With the power always being 'on' at either of the lighter sockets, it allows you to easily connect a battery tender to the car or leave a device plugged in and charging, like an IPOD.
I leave mine connected while I'm at work, but unplug it when the car is going in the garage for a few days +.
Works for me. YMMV
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Location to fob
This happens only when using the lighter plug in the center console I've noticed. Does not happen if using the one in the ash tray. It is just far enough away from the fob.
What we should get is two outlets (at least). One switched, one not.
Anyway, thanks for the tip.
Same kinda thing happened to me. I work at a place that requires a "pass card" to enter the building. It's a totally passive device. If its in front of my FOB in my pocket I get "no FOB Detected"!
Exactly my situation. Just happened a few weeks ago. Dreaded no fob, wont' start. I remembered reading about the cell phone charger plugged into the center console here. I looked.....yep it was plugged in, but not attached to my cell phone! Unplugged it. Car started right up....
Evrose had the right answer to why? Whenever a transformer device is plugged into power, even when the device is not being used, the device acts as a miniature transmitter, giving off (EMF), and yes it will interfere with the FOB system. 40 years in Electronics, many years ago, and I surprised myself by remembering that.
Newer chargers use switching technology to change the voltage rather than the old transformer technology. The reason for this is twofold, it is cheaper and it also wastes less power when nothing is connected to the charger. The downside is that the switching transistors are electrically noisy. Get the right noise and the right placement and significant interference can happen. Switching power supplies can be easily identified because they are so light...there is no heavy block of metal there as there was in the old transformers. Many "wall wart" type home power supplies are also switching as there is a push for more power efficiency from these supplies that are usually plugged in 24/7.
1 Post
NCM Lifetime Member
Just an FYI-
The C6 fobs transmit at 315MHz.
May help you track down interference if you can access the specs. of the potential offender.
