tire pressure
Old May 15, 2012 | 05:40 PM
my2005vette's Avatar
my2005vette
2nd Gear
Default tire pressure
My DIC dispalys a flat left rear tire, but the tire pressure is OK....HELP
Old May 15, 2012 | 05:43 PM
snowsnyper's Avatar
snowsnyper
I believe a battery resides in your sensor inside the tire.
Old May 15, 2012 | 05:44 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Welcome Aboard, we hope you enjoy the car!
Typically-
1. Sensor or sensor battery is going bad. Sometimes reprogramming all four will help, or replace and reprogram. Sensors are said to last 10 years so you are getting closer to that point.
or
2. Some work was done on your car in the past, and sensors got switched around. Could be that it's actually your right front that is flat. Use a hand gauge to check each tire. Reprogram all four if needed.
Good luck to you.
Old May 15, 2012 | 05:46 PM
johnodrake's Avatar
johnodrake
Moderator
Likely a failed sensor. You can try having them re-learned and see if that helps. Otherwise, have a tire shop, that is qualified to deal with your tires, replace the sensor.
Old May 15, 2012 | 06:17 PM
my2005vette
2nd Gear
Thanks this is my first vette and have been enjoying it. I'll get the sensors repalced and not have to worry about it for a while.
Old May 15, 2012 | 06:22 PM
JoesC5's Avatar
JoesC5
Stick an icepick through your tire so your tire pressure gage reads the same as the DIC. Hope this helps. J/K with you. Enjoy your new car.
Old May 15, 2012 | 07:41 PM
Don-Vette's Avatar
Don-Vette
As stated above, bad tire sensor.
To tire pressure
