Major problem please help
Old May 20, 2012 | 09:50 AM
  #81
jumm's Avatar
jumm
FortMorganAl, Please excuse me for hijacking this thread. I didnt think I was doing any wrong since this was mentioned in the thread. Thank you very much for the info! Jim
Old May 20, 2012 | 09:54 AM
  #82
jwaldro2's Avatar
jwaldro2
I'm getting a spare key in case I lock the fob in the car. I have the original key though and was going to mount it with a magnetic thing to the car somewhere but just realized that the car is fiberglass so does anyone know where I could do this? This is the first thing I've had happen like this. It was confusing at first but thanks to all you guys it is fine. Is there a reason I should turn off auto lock bc even with the dead battery I can't open the doors whether they are locked or not.
Old May 20, 2012 | 10:47 AM
  #83
BlueOx's Avatar
BlueOx
-Familiarize yourself with alternative ways to get in the car.
-Get a 'flat' (no plastic end) key made so you can have it in your wallet.
-Ace True Value carries (or used to carry) the B-106 key blank.
-Did you use distilled water to fill the battery?
-Charge your battery FULLY as going around the block does nothing.
-Don't leave the fob in the car. IMHO there is no real reason to do so.
Old May 20, 2012 | 11:02 AM
  #84
jwaldro2's Avatar
jwaldro2
I'm getting the spare made Monday. So if they have a b-106, it will work? Yes I used water. Also I charged the battery fully bc when I went through the CPU it was around 14volts
Old May 20, 2012 | 11:18 AM
  #85
BlueOx's Avatar
BlueOx
To the best of my knowledge it was a Saturn b-106 key blank. The b-106-P is the one with the plastic end. The b-106 with no plastic end looks just like this one.
Old May 20, 2012 | 11:23 AM
  #86
jumm's Avatar
jumm
If you go to Home Depot the key is Axxess # 28. I just went and had 1 made and works perfect. Less than $2.
Old May 20, 2012 | 11:39 AM
  #87
RACE U's Avatar
RACE U
From: Louisville Ky NCM Lifetime Member 429 (Member Since 1993)
St. Jude Donor '12-'13, '16
Get your vin number and take it to your dealer. They probably can cut you a new key.
This is not the first time something like this has happened. There must be a solution.
Old May 20, 2012 | 11:42 AM
  #88
RACE U's Avatar
RACE U
Sorry. I didnt see that you had determined a way to get in.
Old May 20, 2012 | 12:17 PM
  #89
rayk's Avatar
rayk
Originally Posted by Gearhead Jim
Low voltage on the car battery has been known to cause everything except tooth decay, and maybe that too.
Dang funny.
Old May 20, 2012 | 12:32 PM
  #90
jwaldro2's Avatar
jwaldro2
Thanks guys new key will be made tomorrow.
